FOX FORK Prob.
FOX FORK Prob.
I just bought a 05' stumpjumper used and the front fork feels really odd. I was riding a rockhopper with Manitou and it feels similar to that when it was going out. I tried adjusting it on the top, still clicking as if something is loose inside but only when I hit something ( not all the time). I then tried tightening the bottom nut it broke completly off. POS. come to find out the entire bolt is hollow aluminum, just snapped! I only put probably 40lbs on it.
So, what are my options?
hope someone can help.
thanks
Donna
thanks
Donna
Always find my way home
Bikes: Madone, 8500
A few dtails plz...Which model fork? And what did it feel like? What do you mean by going out? If it feels loose, i.e. when you rock the bike b/f with the frnt brake locked, you may have bushings needing replacement. As for the bolt you can order replacements. Still, id like to know more details about the fork.
The Red Lantern
One of the bottom nuts on the Fox is left hand thread, looks like operator error. For the RL models anyway, they come on the Stumpies.
And, is the headset adjusted. The Fox forks are pretty noisy but I have yet to see one that is loose.
Are you a registered member? Why not? click here to register. Its free, and only takes 27 seconds!
Help out the forums, abide by our community guidelines.
I am in the woods and I have gone crazy.
Bikes: MTB's & a Cyclocross
thanks
Donna
thanks
Donna
hey thanks to those who offered ideas. yeah seems funny that I'm a car mechanic yet break a stupid bolt off my new bike
The fork model is a F80 RL. There's not slack or movement in the headset when rocking b/f with brake on or anywhere else. You said that these shocks are noisy- this is my first FOX Shock. Well it feels smooth most of the time except when I hit a root say I feel a "click" instead of a natural roll. If this is normal great, I guess I'll take it in and have someone go through it. If I can replace that rod-bolt that goes through the right shock it would be great.
If it is the right side, it sounds like you broke the "base valve" at the bottom of the damper cartridge. You'll need a replacement base valve, crush washer, bottom nut, and I'd recommend a new dust wiper kit, fork oil, and a flout fluid pillow pack (do do a standard service while you have the fork apart. Call Fox 1-800-fox-shox ext 6550 to talk to the service department and order the parts if you want to do it yourself. Downloadable manuals are available at www.foxracingshox.com. You can also take it in to any shop and they should be able to fix the problem and do a service while they're at it.
By the way, what's a flout fluid pillow pack?
Al
Al
Al
It is a one-time-use packet of 5cc's of float fluid. It looks like a pillow, hense the name.
Al
