Tear in sidewall
Tear in sidewall
Old 03-17-06 | 02:59 AM
Jared88's Avatar
Nightrider
Bikes: Ellsworth , Scott , Giant
Tear in sidewall
Hi , i have a tear in my tire sidewall which seems to be caused by a sharp stone. It is only on the surface so should i do anything about it? Thanks.
Jared88 is offline
Reply
Old 03-17-06 | 03:13 AM
wethepeople's Avatar
Long haired freak.
Bikes: 2011 SE Old Man Flyer.
What kind of PSI are you running? It might be fine if it's low enough. Also whats the sidewall constructed of?
If it was me I would just throw a bike patch inside and keep going.
"the bus came by and I got on, that's when it all began...there was Cowboy Neal at the wheel of a bus to never-ever land."
wethepeople is offline
Reply
Old 03-17-06 | 06:07 AM
It looks insignificant.
If at any time your inner tube starts to bulge out through the cut, then consider placing a patch on the inside of the tire. Otherwise, you've got a lot more miles left on what looks to be essentially a new tire.
Bob
Bobby Lex is offline
Reply
Old 03-17-06 | 07:54 AM
landstander's Avatar
darling no baka
From: I come from a place where the nuts hunt the squirrels
Bikes: Bike Friday New World Tourist, 2005 Trek 520, 2005 Raleigh Companion
Fortunately, it looks pretty minor. I'd suggest filling it in with a small amount of Shoe Goo, mainly to prevent grit from accumulating inside the tear. You should be able to find the stuff in the adhesives section of your LHS (local hardware store).
Dragon... ATTACK!
landstander is offline
Reply
Old 03-17-06 | 09:37 AM
sch
20 Anniversary
Check the inside of the tire for any evidence of full thickness tear. If present glue a tube patch inside the carcass there. Otherwise just remember to check the tire periodically for bulging in the area and goop is a good idea. You will find that at least 1/3 of the tires you throw away will be because of sidewall or occasionally tread cuts too big to patch. The rest will wear out.
Steve
sch is offline
Reply
Old 03-17-06 | 11:05 AM
Matt Gaunt's Avatar
I got a worse gash on my sidewall when the tire was pretty new and now I keep it as a spare.
I rode it for another hundred or so miles first though and it seemed fine. The only reason I swapped it was because I was entering a challenge ride and didn't fancy the roadside jiggery-pokery that comes with a rear blowout.
Matt
2018 Enigma Excel Pic|| 2010 Kinesis Decade Convert2 Pic || 2008 Kinesis RC2 Pics || 2007 Kinesis Pha5e Pics || 2005 Kinesis RC Pics || 1996 Raleigh Max Pics
Matt Gaunt is offline
Reply
Old 03-17-06 | 11:47 AM
supcom's Avatar
You need a new bike
20 Anniversary
Unless the gash goes through the casing, it's of no consequence.
supcom is offline
Reply
Old 03-17-06 | 10:46 PM
Deanster04's Avatar
Bikes: Cinelli Supercoursa 69, Ritchey Breakaway Cross, Mondonico Diamond Extra 05, Coors Light Greg Lemond (built by Scapin) 88, Scapin MTB, Stumpjumper 83, Specialized Stumpjumper M4, Lemond Poprad 2001
Check the tire carefully for any evidence of cut casing threads. Use a magnifying glass. If there are any threads cut then toss the tire or use it only on your startionary trainer. Otherwise, place a patch on the inside of the tire at the location of the cut and ride comfortably.
Deanster04 is offline
Reply
Old 03-18-06 | 02:33 AM
Jared88's Avatar
Nightrider
Thanks for the advice , i have heard of a something called rubber cement. Can i use it on the sidewall?
Jared88 is offline
Reply
Old 03-18-06 | 05:30 AM
No. Rubber cement is not durable enough. Use Goo, as suggested by a previous poster.
Bob
Reply
Old 03-18-06 | 06:44 AM
Jared88's Avatar
Nightrider
Ok thanks alot!
Jared88 is offline
Reply
Old 03-18-06 | 07:44 AM
thomson's Avatar
20 Anniversary
I'll go against the grain a little and suggest you replace the tire. A lot depends on the type of riding you do. If you ride around the neighborhood and it is a fairly new tire, I might patch the inside and use it as a rear tire. The rear is preferred as the tread will wear faster and if you should flat, there is less of a chance you will crash.
If you ride great distances and downhill speeds, I would chuck it.
I buy tires 10-12 at a time and tend to discard tires quicker than my peers. But I do not want a sidewall failure as I am taking a turn at 50mph down a nice long grade. So if I see any imperfections, I chuck it.
If you have a friend that uses a trainer, give him the tire.
thomson is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
