Kevlar beaded road tyres develop an "S"
Old 12-11-02 | 08:05 AM
20 Anniversary
On my road bike I have been using Vittoria Courier Clinchers for several sets and am happy.
Today after a ride i was riding slowly home and suddenly noticed a "bump" in the ride and lo and behold the tyre has a slight "S" in one part of the tyre but enough to make it rub. I had put in my normal 100psi in the morning after changing the tube as the valve was leaking. One of the guys said I must of rode through some diesel?
Anyone seen this before?
I just had a thought, could my floor pump gauge be really offf?
Slightly crooked,
Erik
Mzungu is offline
Reply
Old 12-11-02 | 07:05 PM
VegasCyclist's Avatar
suitcase of courage
20 Anniversary
an 's'? if there is a bulge on the tire, you might want to check and make sure the bead is not coming out of the rim in this area, which would create a bulge, probably because the tube is not fully inside the tire, and it pushing against the wires... but I'm not exactly sure what you mean by 's'
-VegasCyclist
"Daddy made whiskey and he made it well.... cost two dollars and it burned like hell...."
Register!
VegasCyclist is offline
Reply
Old 12-11-02 | 10:49 PM
20 Anniversary
THe bead was properly set. there is a bulge on each side but not opposite of each other, so it looks like a slight "s". It isn't like a bulge but the tire moves to one side or the other but not like it has rolled to the side but like the tyre was malformed, which can't be becuase it has 1000km already. Even deflated i see the tyre isn't straight anymore. the bead seems okay but it is like the kevlar plys have let go. Inside it looks fine.
I guess no one has seen this.
Erik
Mzungu is offline
Reply
Old 12-12-02 | 06:05 AM
chewa's Avatar
The Flying Scot
20 Anniversary
From: North Queensferry Scotland and London (and France)
Bikes: Custom (Colin Laing) 531c fast tourer/audax, 1964 Flying Scot Continental, 1995 Cinelli Supercorsa, Holdsworth Mistral single speed, Dahon Speed 6 (folder), Micmo Sirocco and a few more
I sometimes get this on normal beaded tyres, when the bead doesn't fit evenly all the way round. The low spot causes a distinct wobble
plus je vois les hommes, plus j'admire les chiens
1985 Sandy Gilchrist-Colin Laing built 531c Audax/fast tourer.
1964 Flying Scot Continental (531)
1995 Cinelli Supercorsa (Columbus SLX)
1980s Holdsworth Mistral fixed (531)
2005 Dahon Speed 6 (folder)
(YES I LIKE STEEL)
2008 Viking Saratoga tandem
2008 Micmo Sirocco Hybrid (aluminium!)
2012 BTwin Rockrider 8.1
chewa is offline
Reply
Old 12-12-02 | 06:41 AM
20 Anniversary
You broke a belt in the carcass.
Throw it away.
Get a new tyre.
Je vais à vélo, donc je suis!
D*Alex is offline
Reply
Old 12-12-02 | 07:47 AM
20 Anniversary
Throw it away.
Get a new tyre.
Thanks Alex. What i really need to know is it something that happens in all tyres or should i look for another brand?
Mzungu is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
