Different size front derailers?
Bikes: '06 Rockhopper Comp
I shopping for new derailers and the front seems to have 3 sizes. 1 1/8" , 1 1/4 , 1 3/8. Which do I need?
https://www.pricepoint.com/detail/138...Derailleur.htm
This is for a 06 rockhopper comp?
Any help and an explanation of sizes would be greatly appreciated
thanks
thanks
Front derailleurs usually clamp to the seat-tube and said tubes come in different sizes. According to the specialized website your rockhopper uses front derailleurs with 34.9mm diameter clamps. 34.9mm*(1inch/25.4mm)=1.375 inches=1 3/8 inches. You might also want to note that you need a top swing, bottom pull derailleur. That SRAM claims to be dual pull, so it's probably alright, but I've never used SRAM stuff, so don't take that for gospel.
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
Another thing you will want to be aware of is that front derailleurs sometimes come in different curvatures to match different chainring size ranges. Additionally, there is the issue of chainstay angle. There was a thread on this subject that was discussed not too long ago.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
u need a , 34.9mm clamp, top swing, bottom pull
top swing means LOW CLAMP!
Bottom pull means the cable is PULL from the BOTTOM INSTEAD OF TOP
