Go Back  Bike Forums > Bike Forums > BMX
pedal grind
BMX Dirt, vert, flatland or street? Drop in the BMX forum to talk to other 20" riders around the world. What is the best BMX bicycle for you? Learn all about it here.
pedal grind
Old 04-10-06, 06:26 PM
pedal grind
do they hurt your bike other than your pedals?
lgfuad269 is offline
Old 04-10-06, 06:29 PM
Hardcore
bmxican505's Avatar
Bikes: costom; haro and dimondback
hey i dont do it but no it shouldnt, unless u miss and get it stuck in your frame or grind the rest on ur frame or summin. other than that its cool!
bmxican505 is offline
Old 04-10-06, 06:32 PM
member
Bikes: Solid AA
Your chainstays are almost guaranteed to get beat to hell and back on pedal feebles and 50-50s.
CMcMahon is offline
Old 04-11-06, 02:35 AM
eightdip's Avatar
Bikes: T1 Ruben
you may also get your sprocket if its on the normal side
eightdip is offline
Old 04-11-06, 09:59 AM
Bikes: I own 1 custom bike, and i'm to lazy to list parts
Only the same amount you would if you run pegs, atleast with 50-50s. Drive side febels coudl be nasty unless you know how to do them real nice.
Speaking of pedal grinds, I just put my pegs on again after being pegless for 2 years, and it is SO different doing pedal grinds compared to double pegs. Double pegs seem so much lower, and not as smooth. I only run pegs, so I can icepick, and febel on ledges, rails. But on 1/4s I still use my pedals because it's smoother and easier I think.
I felt liek telling a story, so get over it.
bmichaelx is offline
Old 04-11-06, 10:57 AM
Perpetual n00b
Bikes: '18 Kona Explosif, '18 Sunday Primer BMX, Giant Roam (ss converted), Old Peugeot (SS converted, broken)
Liked 2 Times in 1 Post
Is it practical to try a pedal grind without taking the pins off one side of the pedal?
MadMan2k is offline
Old 04-11-06, 10:59 AM
member
Bikes: Solid AA
Yes. It just won't be as smooth, and you'll look like a complete jackass when you scrape up the 'crete at the skatepark.
CMcMahon is offline
Old 04-11-06, 08:38 PM
Brian's Avatar
Bikes: 8 bikes - one for each day of the week!
Liked 3 Times in 3 Posts
Give it a go, sparky.
Brian is offline
Old 04-12-06, 11:51 AM
Most skatepark riders no longer do pedal grinds, as it really tears up the ramps/pools. I know at some places, the locals will ask you to stop or leave if you're pedal grinding a lot. Do what you want, but honestly try not to f-up the ramps when you do it, cool?
ettsn is offline
Old 04-12-06, 12:28 PM
member
Bikes: Solid AA
How exactly would a pedal grind mess up the coping? Coping is generally steel, and pedals are either aluminum (the same material used in skateboard trucks) or magnesium (which is softer). Pool coping is another matter, but the park designers/builders took the cheap route if pedal grinds are tearing the park up.
CMcMahon is offline
Old 04-12-06, 12:39 PM
It doesn't usually tear up the coping, rather the deck and also the concrete on pools. And in a lot of pedals, the pins are steel, sometimes hardened. This will tear up mild steel coping, and some of the ramps don't even have steel coping on them, either. Maybe it isn't an issue where you are, but here I've seen guys get asked not to pedal grind anymore. Maybe what I saw was a fluke, and not common. I was just trying to be helpful.
ettsn is offline
Old 04-12-06, 12:52 PM
member
Bikes: Solid AA
And that's why you remove the pins on the grind side of your pedal.
CMcMahon is offline
Old 04-12-06, 01:17 PM
eightdip's Avatar
Bikes: T1 Ruben
or get gusset full throttle pedals with a grind plate
eightdip is offline
Old 04-16-06, 03:36 PM
Prozakk's Avatar
Location: Home (don't change this back to "my own personal hell", Mr. Powermad Moderator, and/or computer savvy hacker).
Why waste time, hit 'em with this:
Prozakk is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
