How to true the Mavic Elite wheels???
Bikes: Giant TCR Comps, Cdale R5000, Klein Q-Pro, Litespeed Siena, Piasano 105, Redline Conquest Pro, Voodoo Bizango, Fuji Aloha
Regular spoke wrench works fine. You will need to hold the blade of the spoke to keep it from twisting. Mavic makes a special tool (available at most shops and online), but you can do the job just as well with a pait of needlenose pliers. Nothing special in the truing operation.
Call up mavic, or go to your LBS for tools.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Originally Posted by AfterThisNap
Not the new ones. They require a splined spoke wrench. Also, using a needlenose plier on the bladed spoke is crappy advice. The spokes are aluminum and very prone to stress risers. Even a moderate scratch from a pair of pliers will make it very prone to popping.
https://www.mavic.com/ewb_pages/p/pro...=2&gamme=route
Today, I believe my jurisdiction ends here...
[QUOTE=rmfnla]Good advice, except the spokes on Elites are stainess steel, not aluminum.
Yup, AL spoke are on the SSC/SL line. And to further that advice, a small rag wrapped around the jaws of the pliers is fine. Do I need to point out all the obvious things in life like flush after crapping, don't eat AA batteries and no radios in the bathtub??!!! Jeez........
[QUOTE=capwater]
I use smooth-jawed pliers; an adjustable wrench will work, too.
Can I eat AAA batteries..?
but...but... needlenose pliers don't have the "mavic" logo printed anywhere on them!!!
Originally Posted by Scooby Snax
... neither does the rag, and there goes your warranty!
I would ask the LBS to true it for you without the proper tool - or ask to use it if you know them well!
Thanks for the responses.
I have heard that the spoke nipple is splined in order to obtain the high tension required for these wheels and a regular 4 sided nipple would just round off. Any comments?
Is the Mavic nipple threaded into the rim and the spoke threaded into the nipple???
ATN you are a Master you just pointed out the philosophy beyond 99.9% of cycling today: "if you do not pay more than 50% of the price because of the name, it is not worth it!"
