Cornering technique at speed, 20"
too many bikes
I've put Stelvio tires, and Crank Bros. Mallet C pedals, on my DT FS. My FS is now much faster than the Helios P8 I tested. Which brings me to .... cornering technique at speed for tall riders, i.e., very top heavy on a folder. What I've arrived at is a motocross technique of "pushing the bike down", i.e., increasing the lean angle of the bike while shifting the rider's weight to the higher edge of the saddle.
At slow speed, hanging your inside leg out and forward, also a motorcross technique, works, but if you use cleats, you have to uncleat and recleat to use the technique. Not something to do at high speed.
Any other high speed cornering techniques for tall riders on 20" wheel bikes?
Raleigh20 PugFixie, Merc
Bikes: 1982 Raleigh Twenty Hotrod Fixie; 1984 Peugeot Premier Fixie, 2007 Merc Lightweight folder
Turn the handlebars in the direction you want to go
I'm a croucher leaner, but I'm not too tall so have no need to worry about top-heaviness..
My Raleigh Twenty site | foldr : A flickr pool | #6460, #5632 & #3407 on the fixedgeargallery
too many bikes
I'll clarify my quesiton: does anyone "hang off" a 20" bike when cornering at speed? The alternatives to hanging off are staying with your c/g vertically aligned, or "pushing the bike down" to increase the lean angle (which feels more comfortable to me at this point, at least with Stelvios).
I know about pedal position and countersteer (above 10 mph, the bars are actually pointing in the opposite direction from your turn; https://en.wikipedia.org/wiki/Countersteer ). My FS is now faster than any 20" bike I've ever ridden (haven't ridden an Air Friday, but I would like to), so I'm worried about things like head shake, placement of CG.
I stay with the bike. I suspect most do. I don't think the phenomena you are noticing is restricted to tall riders. 20" wheels are inherently more unstable than the much larger wheels of standard bikes. The riders center of gravity is well outside of the wheel diameter and therfore the moment arm of any disturbing forces is very long. To hang off into a turn means unweighting the seat and in that instant an already unstable system is going to be upset further just at a time when you want to be setting up for proper corner entry speed, lean angle, etc.
H
H
I stay with the bike. I did skid out once, but I was pedalling through the corner for more speed and hit some gravel. My question is, don't you feel like you can corner faster and tighter on the 20" wheels than on any full size wheel bike already? How much faster and tighter do you want to corner?
Originally Posted by Wavshrdr
So push left, go left; push right, go right. Don't be too agressive when trying this for the first time and at speed. You can snap your bike over quite quickly this way.
juan162
too many bikes
My reluctance to stay verticaly aligned with the bike is psychological. I had no trouble staying with the bike with the 20x1.5 OEM tires, or on road bikes with 700x22 tires, but with the Stelvios, I've just entered a new, significantly faster, realm. The Stelvios are "28.6 mm" (1-1/8"). I'm in the 20x1-1/8 adjustment period.
Check your weight distribution over the bike. Folders typically provide a more upright position, with more of your weight distributed over the rear wheel (and your bum) and less over the front (hence many folder-riders' need for thudbuster seatposts, sprung/extra plush saddles). If you dial a little stretch into your bike with a longer stem, you can center your weight more evenly betwen the 2 wheels...
https://www.beginnertriathlete.com/cm...p?articleid=65
Bruce
too many bikes
@ Bruce, yes stock rims, an '05. The rims aren't too bad for machine built. The lateral compliance on both wheels was out by 5 mm when the bike was new. With my 190 lbs, I had to do minor truing for weeks after the first truing until they settled in.
