Where does one buy Loctite?
Bikes: '64 Schwinn Traveler, '73 Astra Tour de France, '79 Fuji Gran Tourer, '86 Dahon folder, '94 Specialized Hardrock, '95 GT Timberline, 2005 Jamis Aurora
Wal-Mart carries Loctite 242 in the automotive section, which will meet your bicycle needs.
Loctite make A BUNCH of different threadlockers. In simplest terms, Loctite that can be removed cold is blue in color; Loctite that requires heat for removal is red in color. For bicycles, you want something that is "medium strength;" "removable with hand tools;" and most simply, "blue." For example, the Loctite 243 mentioned earlier is the oil-resistant version of Loctite 242. If you go to an auto parts store, then you can just ask for "blue" Loctite.
Bikes: 2008 Salsa Fargo
Loctite 248 is even better as it is a stick. It won't dry out/leak while on a tour: Loctite Threadlocker 248 Medium Strength Stick
BTW, some online cycling stores sell Loctite products too but for inflated prices, usually double the prices of hardware/auto parts stores. Stick with them...
Prairie Path Commuter
Bikes: Marin Palisades Trail
Interesting that this just came up. I just sat down after applying some blue to the 4 hex screws that hold my rack on. These screws always come lose. I replaced them with stainless steel screws so I hope this and the loctite does the trick.
loctite is pretty expensive stuff. if you run out, or dont wanna buy it in the first place, crazy glue gel makes a good sustitute. dont use it on plastic materials as it tends to weld the plastic parts together. but it works great on steel and aluminum fasteners.
Bikes: 2004 Giant Cypress, 2006 Trek 7.3 FX, 2007 Gary Fisher Wahoo
If you have a Menards close by, they sell the little tubes for about two dollars.
Fingernail polish makes for a cheap loctite and also works on plastic. If you have a lady close, by then it should be easily available. Look for the clear. LOL
