Trying to make a cheap fixed gear
Hey all,
I got myself a road bike and i'd like to make it into a fixed gear for as cheap as possible.
I know with the front sprocket i can pretty much just use whatever size i want and adjust the chainring bolts. My main problem is what to do with the rear cassette. Can i just keep whatever size cog i want and take the rest off making some sort of spacer and weld it in place ?
https://s81.photobucket.com/albums/j222/bikekilldestroy/ are pictures of it
Thanks.
Thanks.
The formula track hub, or Nashbar track hub are both considered good durable hubs. The Suzue basic and Junior, and Sovos hubs are considered OK by some, garbage by others, depending upon who you listen to, they will eithere require more maintenance, or fail spectacularly. either way, it's not worth the twenty bucks you'll save get the Formula or Nashbar hub. Surly, Miche, and Suzue Promax are also considered good, but they cost a bit more
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Do a search for bumbike. Just remove the current freewheel and thread on a cog. Cheap and easy. Just do us all a favor and leave the breaks on.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
I thought this type of wheel was a cassette type w/multiple cogs not a freewheel. If i can just thread on a cog, what type do i need to get and do i need some sort of spacer for the chain alignment also if i can just thread a cog on do i still need to weld/immobilize the coasting aspect of the hub?
I'm ******** when it comes to anything over a 20" bmx so sorry if i come off as a little dumb.
Cornucopia of Awesomeness
that's not a cassette hub. it's a freewheel hub.
search for "bumbike" or "suicide wheel".
then go read sheldon browns fixed gear conversion page.
then go buy a real track hub.
Car magnet
Bikes: 80's Hoffy track frame 49x15, 80's guerciotti track 47x15(destroyd by a car), '78 ross conversion(RIP, died of old age), '06 fuji track(RIP, hit by a trolley), '75 Alan Aluminum(in the works)
i originally welded the cassette on my conversion, but i made the mistake of riding it with no brakes so the only thing that held the cassette to my hub was 30 years of rust and old age, eventually i hit a rather large pothole while skipping and completely destroyed the rear wheel....
then i upgraded..
thats a durace cog and a bottom bracket lockring threaded onto a road freewheel hub on my old conversion, i used large amounts of red locktite because i don't have brakes..but i would greatly reccomend using brakes if you are going to suicide hub it.
I'm mechically inclinded and know bikes so i know the obvious stuff. Would getting a cog and a lockring and maybe welding that into place work well ? Where can i get cogs and lockrings that will work.
I took the wheel off to get the freewheel off, and alas its a freehub. So back to square one i need to search out a freewheel wheel in order to get this done.
<3s bikes
Bikes: lots
BikeKillDestroy, how did you determin that its a freehub? I'm almost... nay completly sure its a freewheel and that you can just remove it [with the right tool]. Your LBS should do it for no more then $5 if that.
They told me it was, and when i double checked the spoke protector clearly says.. "for freehub"
I could take a picture of it if you like, but there are no slots for the freewheel which initially made me think.
Hello.
Originally Posted by jim-bob
Is it a helicomatic or something?
to the OP, nice name.
Yea i was looking at it and didn't think it was a freewheel, but to be sure i went there and the dude started to say it was a helicomatic, then corrected himself saying it was pretty much just an ancient cassette. Whatever the case i'm still on the lookout for a freewheel setup so i can rock a ghetto fixie ****!
