puzzling PX-10 serial number...
Bikes: Peugeot PX-10, Spitz cyclocross, Specialized RockCombo, Bridgestone MB-1, Trek 720
Hi All,
I'm trying to date my PX-10 and the serial number doesn't seem to follow the pattern described here:
https://www.classicrendezvous.com/Fra...10_history.htm
Apparently "there are six digits used on bikes from the 50's and 60's and seven digits used on bikes from the 70's." However mine has only 5 digits (726**). It's stamped on the bottom bracket shell and it definitely does not look as if a number was scratched out or not embossed deeply enough. I'm pretty sure there was never a plate with a serial number on the bike; in all the pictures I've seen of the plates they are riveted on in two places. There is only one hole in the bottom bracket on this bike, and I'm pretty sure that's the drain hole (sorry, don't know the technical term).
My father bought the bike in Cambridge, Massachusetts in 1970 (for something like $250). The bike has the black and white paint job, fancy Nervex lugs and fork crown, and chrome tips on the fork and stays. I've used this bike since I was in high school in the late 80's and would never sell it. I'm just trying to find out more about it.
I'd be happy to provide more info if it might help someone make a better estimation.
Thanks,
Greg
PS Is there any compelling reason NOT to list the complete serial number? I don't think it's a problem for a 36 year old bike but I'm a bit paranoid.
Thanks,
Greg
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
Are you certain it's a PX-10? Peugeot made many models of bikes that were similar in appearance at a glance (including some variants of PX-10's).
Airborne Titanium
Bikes: Airborne Ti Upright, Raleigh M-20 beater, Peugeot Folding
Talks about plates added to the bikes in the 70's with the serials on them.
hunter, gatherer
the most helpful thing at this point would be good pictures of the bike, decals, and head lugs..
nervex changed the style of their professional series lugs early on...
also, if you think the components are original, these would help date the frame..
the crankset is a good start
I have what appears to be a very run of the mill UO8. The serial number, however, is only four digits, which I read someplace, most likely Classic Rendezvous, is supposed to indicate a track bike frame. Mine clearly isn't, lacking horizontal dropouts & high quality tubing.
Quoted: 443 Post(s)
Liked 27 Times
My 1974 Px10LE has the two holes for the S/N plate, but there is no plate. There is a six digit serial number stamped into the steel where the plate should be.
A much better way to find out when your Peugeot was made is to post pictures here.
hunter, gatherer
hey!! my px10 is the exact same way!
6 digits, two holes for a plate, no plate..
how did you date yours accurately ?
i could never find a good resource for decals online after the classic rendezvous links broke...
mine has the 'peugeot' on black background
decal headbadge
record du monde...
decal headbadge
record du monde...
pics of puzzling PX-10...
Okay, here are some pics of the PX-10. I won't worry about showing the complete serial number now...in the interest of dating the frame. It's clearly stamped 72677.
None of the components are original except for the headset, brake calipers and levers, shift levers and bottom bracket. I replaced the original Stronglight 57 with a Stronglight 99 (which I run w/out using the front derailleur, effectively making the bike a 5 speed). The bike is currently out of commission pending a few repairs and part swaps. You can see that the front wheel is 700 while the back is 27"; I've got to get a tire on the other 27" to have a matching set. The short cage Suntour Cyclone derailleur probably won't work with the megarange cassette so I'm looking for a suitable long cage.
Any ideas about the age? I'm almost positive this is a PX-10 but if anyone thinks otherwise I'd like to hear why.
Thanks for your time.
Greg
Greg
Quoted: 443 Post(s)
Liked 27 Times
decal headbadge
record du monde...
decal headbadge
record du monde...
I think I have a link to decals for $90 on my home PC. I'm at work now.
Mine looks like this:
https://community.webshots.com/photo/...68014369GPeTnK
Vello Kombi, baby
Bikes: 1973 Eisentraut; 1970s Richard Sachs; 1978 Alfio Bonnano; 1967 Peugeot PX10
Quoted: 80 Post(s)
Liked 14 Times
Your decals (both pictured PXs in this thread) are early to mid seventies. I'd put post number 8 at about 1971; that's purely a geuss based on frame geometry and lugs. Posistioning of the 531 decal (if extant it will be either on the seat or downtube) is a good dating clue; the last year for it on the seat tube was 1973, as I recalls. The one in post #7 looks like a PX10E, 1973... however, I'm dealing with tiny internet photos here, and have been known to make mistakes a plenty. Both bikes are in that range, I think, from about 71-3.
I have a 73 which I've dated exactly because I have the original reciept; a 72 (clear from plainer lugs and position of 531 decal), and a 67 (identifiable by components)
"It's always darkest right before it goes completely black"
Waste your money! Buy my comic book!
Earlier than '71...
Poguemahone,
The 531 decals are long gone. I know for sure there was one on the fork because the triangular outline is still discernible. I *think* there was another on the seat tube; I'll look for clues when I get home. I don't recall a 531 sticker on the downtube at all.
If it helps I have pictures of my father out for a ride on this bike and the pics are dated (not by handwriting but by the Kodachrome printing process) June or July 1970. That was a month or two before I was born so it sticks in my mind. My father just wrote and said that he remembers buying it "at the bicycle shop on Bow St. just off Harvard Square" in '69 or maybe '70. He added that he can't be sure about this though.
I'm curious about my 5 digit serial number and the information about PX-10 serial numbers floating around the internet. Do we need to revamp the data?
It's really too bad that the PX-10 Database was abandoned and that several of the pages are no longer accessible. Does anyone know what happened?
greg
greg
Quoted: 85 Post(s)
Liked 5 Times
For decals, check with Andy at Yellow Jersey, or see this link to their web site:
https://www.yellowjersey.org/peudecal.html
I recently obtained a set of these for my 1972 PX-10. They appear to be correct except that the head tube decal says, "Made in France" on it.
Vello Kombi, baby
Quoted: 80 Post(s)
Liked 14 Times
I've seen obviously mis-stamped Peugeot serial numbers before, so I suspect that explains yours. Obviously, I don't know, but that's an explanation. I know the earlier bikes had a different decal set, but I've never prescisely established when the switchovers were. Bike could be a 69 or 70. It's not earlier, and no later than about 1973/4 or so.
Quoted: 443 Post(s)
Liked 27 Times
