Railroad tracks are evil bike eating monters from hell
Bikes: Surly Cross-Check, '85 Giant road bike (unrecogizable fixed-gear conversion
Ok, I didn't crash, but almost. And it would have been my fault. Today I rode my first full commute on my fixed gear bike. For over two years I've done the same route on a road bike. On Industrial Blvd near Harbor Blvd. in West Sac. is a really bad diagnol RR crossing. What I always did was hopped the front wheel over the sections and my rear would follow.
Well, today I tried the same strategy on my fixed gear. I'm not sure if my rear wheel got air, or what but something really bad happened. I felt like my bike suddenly turned part bronco and decided to try and throw me off. My left clip came undone, and the pedal smacked me in the ankle. The whole thing pushed me forward and I just barely manage to maintain control.
This particular track is very wide, very deep and very diagonal. There's no shoulder and even if I take the lane and try to cross it at 90 degrees, I can't.
So how do I get around this track. If I slow way down, then I can't really take the lane safely. I don't mind slowing, but if I did and went straight across (straight in relation to the road, not the tracks) would I be Ok crossing? Can I hop my front wheel if I slow down?
Bikes: some piece of s h i t
Most tracks are not a big deal but some of those diagonal ones are really sketchy. I just slow down and do it carefully. Theres one near my house thats semi-diagonal and has 3 sets of tracks. it sucks.
edit: and yeah, you should be able to hop most of your weight over it, you probably just timed it wrong or something.
Rocket Hips
Maybe on your roadie, youre better at unweighting the rear wheel, which takes some time on a fixed. I hop the front wheel too, and the rear follows without a problem for the most part, unless it is wet. Does crossing at 90 degrees bring you into traffic? If the tracks are really bad, you may just have to wait for a clear spot in traffic to swing out a little wide.
blah
Liked 5 Times
my daily commute involves me going through an intersection clogged with 3 different roads turning in on each other full of tracks (litterally about 15' of tracks all at different angles) Just have to take it slow. Theres another part of my commute where I have to take two tracks comming from perpendicular turning into parallel to me in opposite directions. I take the first one from the outside of the lane towards the inside, then back again, sort of making an S. Just gotta hit it right. It's not worth bunny hopping with the front wheel, its more important that your back wheel isn't gonna hit it at a direction where itll get stuck.
or tarckeemoon, depending
Bikes: Davidson Impulse, Merckx Titanium AX, Bruce Gordon Rock & Road, Cross Check custom build, On-One Il Pomino, Shawver Cycles cross, Zion 737, Mercian Vincitore, Brompton S1L, Charge Juicer
I cross a diagonal set twice a day. They look harmless enough, but it sucks in the rain with a car bearing down on ya.
Bikes: trek 6700 mtb, raleigh rush hour
my ride home every night crosses a set of tracks that Y together, when I first started riding I managed to put my wheels into them twice in a month. The first time I somehow managed to ride it out, the second time I flipped over my bars and trashed a bagful of groceries that was on my back. For those of us in boston, it was the tracks by the packard's corner T stop where comm ave and brighton ave split off from each other, anyone else ever been taken out by them?
I sing the body electric
Bikes: 2006 CrossCheck, Fuji Track 2004
Originally Posted by ~stella
gotta love 12th street in philadelphia!
I bent the **** out of a steel 27" rim riding over a railroad bridge once. Bumping over those ties is murder on road rims. Never had a problem on 26" MTB rims. Oh well. I Straightened it with a hammer and a vice, and rode it slightly lumpy until I found a good Arai aluminum replacement.
redonkulous
Bikes: 2001 GT GTB
Originally Posted by celephaiz
IMO west philly/ucity is far worse... more trolley lines that like to turn in all kinds of directions (like at 40th and spruce where there's a crafty combination of a three way trolley intersection and really, really ****ty road condition)
LF for the accentdeprived
Just practice hopping your wheels on a fix. Since you can do it on a freewheel and use clipless, it is not too difficult. I learned in a couple of weeks, maybe practicing 2 hours all put together. Railroad tracks are no problem now. (I also hop curbs on my fixed, up to 1 foot high as well. Not as easily as on a freewheel, and I still don't have the balls to try an all-out bunny hop with both wheels in the air at the same time. I have to slow way down for higher hops as well. With a freewheel, I could just attack a curb at 20mph and fly up... I don't think that will ever happen on a fix.)
Just practice in a parking lot.
i am batman
armchair touring
i've become the lord of the tracks. track master flex. luke trackwalker.
Today I was on my road bike and I tried slowing way down. I was able to turn my wheel enough that my front crossed the track at almost 90 degrees. I didn't need to hop a all.
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
You are brave to ride thru West Sac daily, I hate that ride. As for RR tracks, I usually just lift my front tire a bit as I go over them as you do. I've never had that kind of issue. Do you think you tried to coast? That would give you that "bucking" feeling.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Bikes: khs flite 100, cannondale r800
