wet lube vs dry lube.........
not trying to start a jihad here but i've been a wet lube guy for all my years cycling. i used triflow for many years but in the past couple of years went to boeshield T-9.
i finally got the bright idea to try a dry lube so i bought a bottle of white lightning.
i figured WL could cut down on drivetrain maintenance, which i like to do less and less the older i get.
anyhow, WL works pretty well but it seems i get a bit better shifting with wet lube.
don't get me wrong, the difference is slight but it does seem that boeshield shifts a little better.
i plan to use the WL for at least a couple of months because it is a good lube and my drivetrain is just as quiet as with boeshield. if WL works out for me it'll be my summer lube.
erader
erader
Quoted: 421 Post(s)
Liked 690 Times
I switched from WL to Pedro's Ice Wax. Still a dry, wax based lube, but I like it lots better that WL. Doesn't seem to leave the residue behind and still keeps the drivetrain clean.
Quoted: 114 Post(s)
Liked 118 Times
Originally Posted by erader
not trying to start a jihad here ...
erader
erader
I have good luck (good shifting, quiet drive train) with Prolink. Goes on wet, but dries so it doesn't attract crud. My fav for > 5 years.
Bikes: 2011 Lynskey Sportive, 1988 Cannondale SM400
Quoted: 20 Post(s)
There is a difference betwwen dry formula lubes and wax based lubes like White Lightning and Ice Wax. I have been using Finish Line dry for many years without complaint. I tried White Lightning and Ice Wax and found that neither one lasted very long.
Location: St. Louis (Home) & Columbia, MO (School @ Mizzou)
Bikes: 06' Trek 2100
I have used countless brands of lubes and none of them seem to last or perform anywhere close the level of Purple Extreme. Hands down best lube IMO.
https://www.purpleextreme.com/
