Chain rubbing against front derailleur on highest gear... normal?
I just got a Rockhopper Comp Disc and something bothered me today, on the highest gear the chain rubs againts the front derailleur but it also rubs in when in the 8th, 7th and 6th gear, it doesn´t affect performance (seemingly) but the grinding noise is nerve-wrecking, is this normal or does the front derailleur needs adjustment? Also, the 9th gear takes some time and effort to kick in, should I adjust the rear derailleur too?
Thanks.
Thanks.
Thanks.
Thanks.
Also, do a search on "cross chaining" that will answer a few of your questions...
Bikes: 2005 Specialized hardrock pro... pike426, e.13 drs, fsa gap crank, formula k24's, and some more/2006 Scattante R-660 easton circuit wheels.
Originally Posted by free_pizza
if its pretty new, bring it back to your LBS and get them to adjust your derailleurs as the shifter cables have probably stretched a little.
you can take back to LBS, I do agree if it's new they shud have given it to you set up correctly - but you will at some point need to learn how to adjust yr mechs, if you don't want to go to the LBS often...
it is pretty easy and you will get satisfaction fm doing it yourself - go to park tool website & follow the instructions step by step.....
