SS Conversion Woes
SS Commuter
Bikes: Trek 6700 converted to SS;Specialized Stumpjumper FSR
SS Conversion Woes
I need some guidence from those who know. That means you people of this venerable forum :>)
I commute on an Azonic DS1 (horizontal drop-outs) using a Shimano style cassete hub (disc) with spacers and BMX cog. To my eye the chainline is straight. The rear hub has a QR axle, and I have Redline chain tensioners. The front chainring is a 32t Salsa ss ring.
I having difficulty keeping the chain tight. I am thinking of micro adjusting the chain lenght using half links since it's the least expensive solution. What do you think of this? How do you get the chain on when it is at maximum tension? What am I missing?
Thanks
Kevin
Thanks
Kevin
Bikes: Pake Track; Bianchi XL EV2 El Reparto Corse, Kona Jake the Snake
https://www.sheldonbrown.com/chainline.html
Half links are good and will work.
SS Commuter
Thanks for the reply. When the chain is so thight and the hub is right up against the drop-out stop, what is the best way to install the chain?
CTW Streetfighter Pilots
Bikes: 1972 Schwinn Continental SS, 2006 Mercier Kilo TT
Rebel Thousandaire
Bikes: Public D8, Yuba Mundo (cargo), Novara Buzz (1-speed, soon to be 2-speed w/ a kickback hub), Xootr 1-speed folder
Bikes: '78 trek 530 w/ full 600 group, conversion atami '70s frame.
It sounds like you're trying to put on the rear wheel, and then put the chain around the cog and chainring. You have to wrap the chain around the cog and chainring, and then pull the wheel back to tighten the chain and tighten the axle nuts. Experiment with proper chain tightness from there.
