Removing the guide pin? (chain installation)
34x25 FTW!
Bikes: Kona Jake, Scott CR1, Dahon SpeedPro
Ugh, why did I get a Shimano chain when the SRAM chain was soooo easy to install last time? Apparently this 9-speed "HG" chain has a guide pin stuck to a "reinforcing" pin which help install the latter. OK, it's in, but how do I break off the bleeping guide pin? TIA.
Note to self: do not replace chain after midnight again.
Amateur Hack
Bikes: Marin mtb turned tri turned commuter turned singlespeed, Haro Werks 2.0, Specialized Epic Allez carbon main tube built up for triathlons
brute force. it should snap off easily.
34x25 FTW!
Thanks. Do I pull on it or snap it sideways? The diagram which came with the chain suggests pulling.
Amateur Hack
grab it w/ some pliers and snap it sideways. it should be really easy. They are made to break there. Park has some pretty good pages on bike maintenance. here's the relevant page. shimano is about 1/2way down.https://parktool.com/repair/readhowto.asp?id=25
34x25 FTW!
Wo0t! Thanks, finally got it. Once again, one of the handiest tools known to man comes to the rescue, the venerable visegrips!
