Being good to my perenium
如果你能讀了這個你講中文
I'm quite new to the track, and I had some major crotchal issues this past saturday at the Kissena instructional session. On my Soma, I normally have a brooks b17, rising stem, bullhorns and 47x17. Comfy. When it morphs into track form however, it has a really uncomfortable Avenir saddle, drops, flipped rising stem and 47x14.
Which of the following will do the most good for my nether region area between the boys and the void?
-Cycling shorts (probably better for the boys than the perrenium, right?)
-Cutaway saddle (which one?)
-Tilting saddle downwards?
spinlikehell
Hard to say exactly as everyone has different, er, needs in that area, but a coupla points:
- I'd say a definite yes to proper cycling shorts. I use Assos and De Marchi ones and like em both, plus cheapies that come with the team kit. You're generally not riding for long periods on the track, but proper shorts can still stop things getting pinched / rucked up etc
- Why did you flip yr stem over for the track?? If its more comfy for you on the road rising upwards, then I'd suggest leaving it that way on the track. You're already effectively lowering yr bar height by maybe 8-10cm by moving to drops from bullhorns.
Flipping the stem may look more 'track' but leave that stuff to the NJS street kiddiez / velospace pos(t)ers In your case it's only exagerating the increased distance between yr saddle height and yr bars and you ain't gonna gain any speed by being slightly more aero if you're fundamentally uncomfortable on the bike. Your bike handling will also be better with a less extreme position, and this'll help you to win more races on the track than any ultra low position will.
Welcome to the track - keep at it, y'll love it
HTH
mickster
HTH
mickster
it's your bicycle bells
Howdy -- I was out at Kissena the other day, didn't get a chance to talk to you (I was on a Fuji track, riding in the smaller group uptrack from you guys while you were pacelining). Glad you dug it, no reason to be in pain though.
I second the advice...Of course get shorts or bibs, and beyond that I'd say you should leave as much as you can the same between your road (or fixed-street bike) position and your track position; some people like to be rotated a tad forward -- seat a cm forward, bars a cm down), but many, many others set things up identically; so far as I can figure out (does anybody have a better explanation) the downward-angled stem is a relic from the days when people were riding much bigger frame sizes for a given height. These days the only time you really NEED a downward angled stem is if you're putting a bike into double duty as a pursuit/TT bike and absolutely have to get your position lower on the tops for aerodynamic reasons. Otherwise keep your level or slightly rising stem and just swap the bars.
And don't tilt down the saddle; that's only useful if you have some kind of lower back injury you have to compensate for, otherwise it'll just make your hands hurt as much as your rear.
And leave the Brooks on there -- no reason not to go with whatever works for you. I have a San Marco Regal on every bike I own, no matter what its purpose is, for instance.
如果你能讀了這個你講中文
Good advice both. I'll get the shorts.
I dont think the B17 would be any good down in the drops--its like a hammock when you can get your sit bones down squarely on the back, but when leaning forward in the drops, the sit bones and the saddle form less of a right angle and more of an acute angle, putting more weight on the perenium. I think I'll look for a good cutaway, but otherwise take the above advice.
Cut away saddles dont work for everyone. In fact its proven to be a bit of a scam. If your "regular" saddle is possitioned right and your sitting on it properly you wont get those "issues" Specialized speaks of. Nearly eveyone at my shop had one on their Allez's this year and last and took them off almost right away. I rode one last year and hated it. Next time your at the track or a shop ask to sit on a couple bikes with differant saddles.
A personal fav of mine is the Fizik Nisine. I just took it off the track bike and put it on my road bike. Ive been riding that saddle design for 5 years now. Now on my track bike is the most bear bones racing saddle ive ever seen; SGD Ti-Fly. For somthing as stupid light, areo(witch makes no differance) and low profile its freeeekn comfee.
Liked 5 Times
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
Quoted: 15 Post(s)
Liked 9 Times
I'd suggest trying a concor, regal or flite type of saddle for the track.
I also have a B17 and just can't see it on a track bike, with the steep
angles, in the drops positioning it seems it would roll you too far forward.
Personally I don't think cut outs do much, a properly set up saddle that
fits is just as good (imho).
marty
marty
Sono pił lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
