quick question: cone wrench sizes
18 dog baby
Bikes: 2008 crosscheck complete, 1984 Pugeot fixed conversion
i'm buying some cone wrenches from an online retailer. i need to know what size and how many i should get. i have deore hubs front and back on my Trucker. if i want to rebuild the hubs, what do i need? i've done it before, but just don't remember what i used. i just found the right wrenchs lying around the office i used to work at.
thanks!
thanks!
Quoted: 3450 Post(s)
Liked 420 Times
All the hubs I have use a 13 mm cone wrench for the front hub and a 15 mm cone wrench for the rear hub and you usualy only need one of each size as you can hold the other end with an ordinary spanner in most situations but check your hubs anyway. Actualy I've just taken a look at a set of hubs I have that I haven't built up yet and with them you would need two cone spanners to adjust them. There are other sizes out there too so the usualy advise to measure and see.
Regards, Anthony
Regards, Anthony
Quoted: 2026 Post(s)
Liked 1,096 Times
They vary. The 105 and older Ultegra hubs I've worked on require a 13 mm cone wrench in front and a 15 mm cone wrench for the rear hub cones. The locknuts are 17 mm but they can use a conventional box or open end wrench.
Newer Dura Ace and Ultegra hubs use a 13 mm and 14 mm for the front hub and both have to be cone wrenches. They also use two 14 mm cone wrenches for the rear hubs.
What to buy? To cover all eventualities buy 1x13 mm, 2x14 mm, 1x15 mm and have a conventional 17 mm wrench around.
Bikes: '89 Cannondale SC600, '05 Marin Fairfax, '10 Specialized Roubaix Elite Compact
I don't know if thet are still around but years ago I was able to find double-ended Park cone wrenches in a 13/14 mm and 15/16mm. With these two cone wrenches I was able to service just about any hub.
is slower than you
Bikes: Gunnar Sport, Marin Pine Mountain, Gunnar Ruffian, Gunnar Roadie, BMC Fourstroke, Salsa Vaya
"Thank you, sir, may I have another!"
Proud supporter of the Chippewa Off-Road Bike Association (CORBA)
www.chippewaoffroad.org
Gone, but not forgotten
Bikes: See: https://sheldonbrown.org/bicycles
Quoted: 24 Post(s)
Liked 6 Times
Originally Posted by AnthonyG
All the hubs I have use a 13 mm cone wrench for the front hub and a 15 mm cone wrench for the rear hub and you usualy only need one of each size...
See also https://sheldonbrown.com/cones
Sheldon "Two In Front, One In Back" Brown
Amateur Hack
Bikes: Marin mtb turned tri turned commuter turned singlespeed, Haro Werks 2.0, Specialized Epic Allez carbon main tube built up for triathlons
I had to get an 18 for my surly singleator. but when I put my bike together, I hit a magic gear and actually have never used either the 18 or the singleator! bleh!
These are quite nice and an excellent deal to boot. Picked up some about a month ago.
https://cgi.ebay.com/PARK-BIKE-SET-OF...QQcmdZViewItem
'84 Trek 850--spinbackle-built, '85 Trek 670 Campy Nuovo Record--project, '87 Trek 560 SS/Fixed--project, '87 Specialized Stumpjumper Comp w/ Deore XT--Specialized-built, '87 Rossin Record, '03 LeMond Wayzata--commuter,
'?? TST Mtn Bike frame--project, '07 Tsunami Tandem--home-built
