YACL: Yet another Chair Lube Query
Hypoxic Member
I am currently using ProLink. How in the world do you get a small drop per pin?? Do you transfer the liquid to some tiny oil can?? I can only drip a giant blob per pin.
thanx,,,
motto: start slow, then ease off
thanx,,,
Quoted: 2026 Post(s)
Liked 1,096 Times
What's with this agonizing about one-drop-per-pin? Add a slow stream as you run the crank backwards to get the entire chain lubed then wipe off the excess. Your time is worth more than $.05 worth of chain lube you'll waste.
Hypoxic Member
Liked 6 Times
thanx,,,
thanx,,,
It makes my ProLink last a while (it's now $9/4oz bottle at Performance), but more importantly, I don't get a lot of lube where it's not needed, thus maintaining a relatively gunk-free drivetrain.
Regards,
My bike's better than me!
Bikes: (2) Moots Vamoots, (1) Cannondale T2000 tourer, (1) Diamondback Response Comp mtb
I tend to avoid lube threads like the plague, but ... fwiw ... I apply my homebrew by dipping a toothbrush into the bottle, then applying the lube with the toothbrush.
No drip. Goes right where I want it.
Cuts down on gingivitis, too!
Still kicking.
I tend to not lube my chairs.
For a chain, it's either tri-flow or Pro-link.
Appreciate the old bikes more than the new.
Still kicking.
Originally Posted by neil0502
Dinner parties at your place must be a veritable squeak-fest....
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
