Keep bending breaking BB spindles...
genec
Quoted: 13658 Post(s)
Liked 4,532 Times
OK I am 195 lbs, I ride the bike on tours, meaning I carry up to about 70lbs on it from time to time. I am a strong rider.
I have broken two Phil Wood spindles, and have bent the most recent Shimano I chose as a replacement.
What the heck is going on? Are there any "super spindles" out there?
This is a custom made bike, so there is no brand associated with it.
I am using a Campy crank and chainrings... been using the same for nearly 20 years.
Quoted: 2026 Post(s)
Liked 1,095 Times
Wow, I have never heard of ANYONE breaking a Phil Wood bb spindle, particularly not TWO of them and a lot of riders are much heavier than you. Are you, by any chance, using their Ti spindles?
You might talk to the Phil Wood people. They might be curious about seeing the broken pieces. The only thing I can think of is the Spindel length is too long. It is like a lever the longer it is the more force is generates. How long is the spindel?
Listen to me
Spindles are made from tool steel (Rc hardness 58 - 62)
I find it difficult to believe that they can be broken under normal use.
The Al alloy crank arms would fail well before a spindle.
Enjoy
Enjoy
genec
Liked 4,532 Times
Enjoy
Enjoy
I still have that one, but it is slighly bent.
I replaced it with a Shimano about 5 or 6 years ago... now that Shimano is bent.
Hollow or solid it makes little difference. I used to break and twist 19mm bmx spindles all the time too, I'd suggest you either change your riding style(not practical) or get one of them new fangled o/s shimano set ups.
genec
Liked 4,532 Times
Originally Posted by The Fixer
I need to see this for myself....
The broken spindle was sent back to Phil.
New Orleans
Quoted: 157 Post(s)
Spin more.
Wow, that is something. Maybe you should use lower gearing-especially when accelerating.
Tall gearing puts a lot more stress on the spindle.Luck,Charlie
hello
Originally Posted by genec
How, what can I show you? Tonight I will measure the BB and the spindle... need photos of what? Hard to show the bending as it only is visible when the bike is loaded and turning the cranks. (although a runout gauge would show it)
Taking "s" outta "Fast"
time to ditch the square interface. Go with an external BB and a newer hollowtech/gigapipe integrated spindle system and you'll probably find the next weakest link in your drivetrain.
genec
Liked 4,532 Times
likes avocadoes
Bikes: heh, like that info would fit here...
Listen to me
Quick calcs indicate that the crank or pedal axle would bend/fail well before the spindle.
While I can accept that a 15yo spindle might beak (age, fatigue, manuf. flaw), <see earlier post>
Enjoy
Enjoy
Bikes: Litespeed Firenze / GT Avalanche
As you have already found, a solid spindle is more likely to bend than a hollow one.
If I had a bottom bracket that lasted for 15 years, I would get the exact same one again.
genec
Liked 4,532 Times
Originally Posted by BostonFixed
Is it really that much hassle to replace a bb or a spindle every couple of years?
You'd think that after all that time the bb would be in need of a replace/repack.
I would think that the 22 year old bearings would have long ago needed replacing.
Probably should, just for cause.
genec
Liked 4,532 Times
Well, I tore into the spindle/chainring affair last night... Sigh. The hex bolts on either side were looser than I would have liked... didn't take much effort to "break" them loose.
The crank opposite of the chainring felt quite good and tight. But the chainring side seemed to have some wear. Upon closer inspection, there is obvious wear on the mating surface of the tapered square. The chainring mating surface has some obvious wear also. Loose fitting these pieces back together and I can get some rocking motion at the chainring/crank to spindle connection.
I tried tightening the bolts again last night and I could still see a bit of deflection just rotating it by hand (no loading).
Looks like it should all be replaced.
The BB bearings still feel quite good and smooth, with no apparent rocking or movement. I suspect the BB is still in good shape. This Shimano part is, after all, only about 6 years old.
The real question is: Should a Campy crank work with a Shimano spindle... or are there some incompatibilites there?
Taking a good look at other places on this long, hard ridden, bike (22 years) it is evident that it needs a good sandblasting and painting...
How long does steel last anyway?
Yet another vegan biker
Bikes: Sakae Prism, Vintage Fuji bike(S), too many bikes, one from scratch bike.
The good news is that you can get a Campy ACS (Aluminum Cup Solid spindle) BB for around 20 bucks. I picked up several, along with Veloce and Centaur 10 speed cranksets and a ACH (hollow) BB for my Centaur set..
genec
Liked 4,532 Times
Originally Posted by silversmith
They are incompatiblle. They seem to fit but will not position themselves correctly onto the spindles.
Thanks
