Converting a flatbar to drops
Alright, Im getting stuck on what shifters/brake levers to get to switch my bike from a flatbar to dropbar. I have an 8 speed with a double crank and V-brakes, which is making everything kinda tough for me. Im pretty new to cycling so any help anyone could offer would be greatly appreciated.
Gone, but not forgotten
Bikes: See: https://sheldonbrown.org/bicycles
Quoted: 24 Post(s)
Liked 6 Times
Option B: STI with Travel Agent pulleys to make the brake cable pull match.
Even if you could find them, I wouldn't recommend buying 8-speed shifters unless they are _very_ cheap. It makes more sense to upgrade to 9-speed, since the expensive part of this conversion is the shifter, and you already need a shifter!
The only additional parts you need for 9-speed are a new chain and cassette, and these are normally consumable parts anyway--odds are yours are already close to due for replacement.
Some folks will tell you that you need a lot of other stuff to convert an 8-speed bike to 9-speed, but they're wrong.
Also, you can generally use the 9-speed shifters with your old 8-speed cassette by using the "alternate cable routing" shown at https://sheldonbrown.com/alternate
Sheldon "Nine, Ja!" Brown
OK, thanks a lot man. I actually did find some 8 speed shifters for pretty cheap, my main concern is if they will work with my v-brakes or if I need to upgrade my brakes as well. Also, is it possible to use a shifter made for a triple crank on a double?
Quoted: 24 Post(s)
Liked 6 Times
Anything that works on a triple crank will also work on a double, because 2 is less than 3.
Sheldon "Interchangeability" Brown
heck, i just converted a older peugeot US express from flats to drops. and i used a stem mount shifter. this bike is a 14 speed. and friction and works great. except missing tape on one side......
