that wicking material...
Bikes: 2004 Fuji Thrill
am i the only one that this happens to?
when I wear the wicking material, i start sweating before i even start moving. doesn't feel right.
also, what's up with my compression shorts??? on my commute today (the first time I've worn such a thing (x-mart brand)), i felt like i was signalling 'left-turn' during the entire commute. had to manually adjust a few times. annoying!
Quoted: 19 Post(s)
Liked 7 Times
Superfine merino wool is the new high tech wicking fabric. Sheep have been using it for many years with success and they never sweat when cycling.
I wear a nike dri-fit shirt as my base layer in winter. It takes 15 minutes of riding before I start sweating.
Your compression shorts issue would probably be improved with a nicer set of shorts. This should fit better.
My sugoi cycling shorts keep everything in their proper place. My performance shorts do not. To celebrate a promotion I will be replacing the performance shorts in a week or two.
Plays in traffic
Bikes: 1996 Litespeed Classic, 2006 Trek Portland, 2013 Ribble Winter/Audax, 2016 Giant Talon 4
Quoted: 76 Post(s)
Liked 14 Times
I've been reluctant to try cycling garb for exactly this reason.
Whenever I wear ordinary clothing that's not 100% cotton, I sweat inside it, even when sitting quietly in a cool, dry, air-conditioned room. It's like being wrapped in Saran Wrap or a Hefty trash bag something, and I'm sweating even before I'm done getting dressed. I've tried all the synthetics in all sorts of mixtures and combinations, with the same result. I always go back to cotton.
I've experimented with cycling in wicking synthetics using several of the sweat management headbands and skullcaps with exactly the same result. My head begins sweating before I have my helmet on, and I'm dripping after less than a mile.
I've not purchased any of the fabulously expensive cycling jerseys or shorts. Instead, I wear t-shirts and jeans or cargo shorts (but they're hard to find in all cotton.) In the upper 80s and muggy, I'm dry until about a mile from work, or in a longer, harder, recreational/training ride, about ten miles. And most of that is because I wear a backpack in both situations. Yes, once I start sweating, the cotton stays wetter, longer, but I'd change out of cycling garb too at my destination, so what's the difference?
Cycling in cotton is a huge fashion faux pas, but I've resigned myself to the fact that in order to be comfortable, I'll have to take the disapproving stares.
Life is good
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 10 Times
I wear regular cycling clothes for commuting. Winter weight bibs and jersey in the cool months, summer weight in the warmer months.
34x25 FTW!
Bikes: Kona Jake, Scott CR1, Dahon SpeedPro
Originally Posted by RonH
Are you wearing winter weight clothes? Summer weight jerseys and shorts are lighter/thinner.
WTF are compression shorts? Doesn't sound like anything made specifically for cycling.
Compression shorts are just skin tight shorts, they're not cycling specific (I wear them for rugby). Like oboe said, cycling shorts are also compression shorts, but typically not as tight since the purpose of wearing them is different. If someone rides in regular compression shorts though, they'd have to have an ass of steel.. boxer briefs are more padded!
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1233 Post(s)
Liked 1,241 Times
Ooh, I think I pulled up behind her at a traffic light last week! Serious hard-body on a cruiser wearing some spandex daydream hotpants...Michelangelo's polished marble had nothing on this girl.
Mooninite
Bikes: $53 Walmart Special
I wear Under Armor boxer briefs on my commute, not as tight as their compression shorts, but same chafe protection.
When it's cold I wear Under Armor sleeveless compression t-shirt under my regular shirt.
No-Pants Island
Bikes: 2007 Trek Pilot 2.1 WSD & 2001 Specialized Crossroads
My observation: wicking and other synthetics work when they are close to your body, as in a jersey or a tight shirt. They don't work so well when they are loose, as in a regular T-shirt. In order to wick, the sweat needs to be in contact with the fabric, which needs to be in constant contact with your skin.
Which is unfortunate, because otherwise I really like my AlertShirt T's. And, you know, tight clothing makes me self-conscious of areas that are not quite up to polished-marble standards.
Speed Demon *roll eyes*
Bikes: 1998 specialized s-works mtn bike / 2005 Kona Jake the Snake
In all my years of cycling - and I date from the wool cycling short days - I have never had this problem. Weird. I use Giordana cycling shorts (same cut as the tdf riders use - it is what the Waterloo Cycling Club shorts are...) and with these, I never have to "adjust the plumbing" as they fit so well. As well, they are cool in any temp and the only time I sweat in them is if I am actually riding and working at it - riding in cotton, I am drenched in minutes... If I am in my winterweight stuff, I boil almost immediately though since all the materials, synthetic or not, have a high insulation factor. This is a good thing, as the clothing breathes VERY well when in motion, and insulates when soaking wet, which cotton does not. My cycling jacket is ancient - and made of wool with nylon shell pieces on the front only for wind blockage. I will only replace it when it finally dies since I have not seen one in about 20 years like it. If I do ever see one, I will buy it immediately since that material combination is supurb for cold weather riding and wool is amazing when soaking wet - warm, dries fast, and breathes perfectly.
Aren't different body chemistries great ? ;p
Sophomoric Member
I don't think any fabric will reduce sweating. Fast drying is really what wicking is all about, once you get past the hype. They absorb sweat on the skin side, the sweat soaks through to the outside like cotton, but dries much more quickly than cotton. The evaporation produces a cooling effect, much as it would on bare skin.
"Think Outside the Cage"
we are 138
I'm happy riding padfree.
I cut the padding out because it was more uncomfortable riding with a diaper than having an uncusioned taint.
I used to wear cotton, but after geting caught in a thunderstorm under a bridge I noticed that my nylon shirt dried and my cotton shorts didn't. Also they fold more compact so it's easier to stash some spares around. However, if I don't rinse them out in water after a ride, they will reek.
Enjoy
Bikes: Trek 5200
Originally Posted by feethanddooth
i just sweat and love it.
59'er
Bikes: LeMond Maillot Jaune, Vintage Trek 520 (1985), 1976 Schwinn Voyageur 2, Miyata 1000 (1985)
Liked 6 Times
I wear under armor shirts for my commute (less expensive than jerseys). I've noticed a big difference in comfort between bike clothing that wicks the sweat vs cotton.
59'er
Liked 6 Times
But does it make you sweat even when you're not moving?
Enjoy
Bikes: Trek 5200
I wear the UnderArmour sleeveless or DuoFold (ultra thin) long sleeve shirts. Even when it's 50F, I arrive sopping wet
45 miles/week
Bikes: Jamis Aurora
And I know sweat ... any kind of exertion and I sweat like an ice cube in a blast furnace. My shirts will be SOAKED after I do anything significant outside.
Treasurer, HHCMF Club
Now living in the land of the cheesesteak.
But working at a job where I can't surf BikeForums all day any more...
Enjoy
Bikes: Trek 5200
I'm wondering
Whether the wicking stuff looses capability after a year or two?
Whether you sweat the same no matter what...??
I have some wicking thermals from snowboarding that are probably going on 6 or 8 years now, haven't noticed any difference between them and new ones. As long as they're clean they should wick fine, though eventually odors will accumulate like all synthetics and they'll have to get the boot.
