Removing Braze-ons
Bikes: Specialized Hardrock, Schwinn Traveler FIX/SS
Removing Braze-ons
Hello, I'm fairly new to this site, and I was wondering if you could help. I am converting an '87 Schwinn Traveler to a fix/ss, and I want to remove the downtube shifter lugs to give the bike a cleaner look. I also want to remove some of the cable guides and the derailer hanger. I'm planning to repaint the bike afterward, so what is the best method to remove this extra steel? I am trying to do this inexpensively, and I want to do it myself. It's a 4130 True Temper Frame.
Thanks,
zac
Thanks,
zac
WTF?
Bikes: trek cross, gt mtb, khs track
first of all...where are you from. it's impolite to give so little info 'bout yourself.
search for "braze-ons" yields: this thread
the best method is the one youre most comfortable with. Torch? File? Hacksaw? Dremel? Angle Grinder? Sawzall (note, do NOT allow your neighbor to do this) ? Chain Saw? Weed Wacker ?
personally, I'd leave 'em on.
King Among Runaways
Bikes: 2004 Bianchi Pista, Cannondale Track, Soma Pake, Schwinn Breeze
Chew them off.
"I owe everyone an apology" - hyperrevue
I had an easy time using a hacksaw, file, and last, an orbital sander to smooth it all down. Came out perfect.
LF for the accentdeprived
Hacksaw and file. Not quick, but safe.
edit: stevo is referring to this thread. And this is why powertools are not always a good idea as well...
Geek Extraordinaire
Bikes: Bianchi Advantage Fixed Conversion; Specialized Stumpjumper FS Hardtail
Originally Posted by Walkercycles
Niiiiice treatment of the newbie...
First, get yourself a pair of pliers. Use a Oxy Acetelyne torch to heat up the braze on ONLY. As it gets to temp, it will change to a Orange color. Grip said braze on with pliers and give a gentle pull while still applying heat to the braze on. When the filler material reaches its liquidous state the braze on will pop right off. Sometimes this is before the braze on turns Orange, so you need to be ready.
Dont hold onto the braze on with the pliers druing the pre-heat, as heat travels up the pliers and you can burn your hands.
Have fun!
DW
Have fun!
DW
I'd rather have a bottle in front of me than a frontal lobotomy.
Sintesi Conversion Serotta Track
not the car.
yes it will. it takes some time, but it will. probably about 3-4 minutes per braze-on
focus the flame on the braze-on. not the tube. if it seems to be awhile, whack it with a file.
Blowtorch to heat up the braze-ons and a wrench to whack 'em off when they get hot. Er, that sounds pretty perverted, now that I have typed it out, soz.
WTF?
DW
DW
My wife does mosaics with thick ceramic tiles, and thus had a really neat set of tile cutters that were like big, f*ckoff wirecutters but with the cutting edge perpendicular to the handles.
Ah, here's an image of a set:
Anyway, I used those to remove my braze-ons and they popped off with minimal effort. A few strokes with a file afterwards and all was smooth. That seems to be the easiest method, as far as I'm concerned, but I accept no liability for anyone following my advice and jacking up their frame.
That said, I only removed the braze-ons because the frame I'm building up right now is a 1976 era Nishiki Internation and I have NO INTENTIONS of ever restoring it to it's original "glory". I happen to have a grip of frames and other parts hanging around my house -- I would not recommend removing braze-ons to anyone who does not mind utterly and irrevocably destroying the "collector" or restoritive value of their frame.
https://www.pedalroom.com/members/iamtim
Thanks for all the advice. I think I'll try the torch. My Brother is a plumber, so he plays with the torch regularly.
My info: I reside in Springfield, Oregon. I have a 12 minute commute, and I try to commute to work 3 days a week. I've really enjoyed cycling over the past year. I'm currently riding a Specialized Hardrock that's set up with a pair of 1.5 inch smooth armadillos. I'm really excited to get this project on the road.
Thanks again.
Thanks again.
