A strange cause for a flat tire
Old 07-07-06, 11:04 AM
Sophomoric Member
Roody's Avatar
Quoted: 711 Post(s)
Liked 13 Times in 13 Posts
This probably happens all the time, but I've never read about it here.
Last night I had a flat tire on my way home. When I examined the tire, I found a sharp object embedded in it. When I dug it out, I was surprised to discover that it was a wood splinter. Looking further, I discovered two more splinters that had also penetrated the tire. I had been riding on our town's Rivertrail just before I lost pressure. There are many board walks and bridges on this trail, all made of wood. Evidently one of these rough, weathered wooden sections had given me three flats for the price of one. Of course I've been riding on the trail for years and this was the first time I had problem.
I guess I learned two lessons. The first was to watch the wood more carefully when I ride. The second was that if you find the object that caused a flat--keep looking! There might be more sharpies still embedded in the tire.
"Think Outside the Cage"
Roody is offline
Old 07-07-06, 11:07 AM
Sumanitu taka owaci
LittleBigMan's Avatar
Roody, the one that gets me is those little metal "splinters" which come from steel belted tires. You almost can't see them, but when you run your fingers around the inside of the tire, it'll let you know it's there by pricking you nicely.
No worries
LittleBigMan is offline
Old 07-07-06, 01:21 PM
Neat - w/ ice on the side
dalmore's Avatar
Bikes: 2005 Dahon Speed TR, 2006 Dahon Mu SL, 2000 GT XiZang, 1999ish Rock Lobster, 2007 Dean Animas CTI
Yea, there has to be a better way than using your hand to find the sharpies - anyone want to enlighten me?
dalmore is offline
Old 07-07-06, 01:23 PM
-=(8)=-'s Avatar
Bikes: Sngl Spd's, 70's- 80's vintage, D-tube Folder
^^^^ A ball of cotton.
The cotton will shred and small strands will stick to the sharp stuff.
-ADVOCACY-☜ Radical VC = Car people on bikes. Just say "NO"
-=(8)=- is offline
Old 07-07-06, 01:30 PM
MTWThFMuter
Jeprox's Avatar
Bikes: schwinn, raleigh, 'dale, litespeed, bianchi, surly, novara, brompton
Excellent!! This is worthy of being published in BICYCLING mag. If it does, you get something back from them.
Jeprox is offline
Old 07-07-06, 01:51 PM
Is that what those things are? Two flats in one ride last week. What are people doing to their tires to fire shards of metal all over the place?
About the cotton idea: I like it. I could stuff the cotten in the handle of my pump and it also might stop that annoying rattle.
Would it work for glass though? Sometimes glass shards "peak" through inside of the tire only when the rubber is flexed a bit.
ghettocruiser is offline
Old 07-07-06, 02:03 PM
don't pedal backwards...
MacG's Avatar
Bikes: Surly Long Haul Trucker set up for commuting and loaded touring, old Sekine road frame converted to fixed-gear, various beaters and weird bikes, waiting on the frame for my Surly Big Dummy build
People let their tires get so worn that the wire belting inside is exposed and fraying off. Here's an extreme example:
I usually inspect tires by folding them inside out as I go around. This stretches the inner surface of the tire and makes any holes or lodged objects stand out more than just looking and feeling alone.
MacG is offline
Old 07-07-06, 02:24 PM
Crankenstein
bmclaughlin807's Avatar
Bikes: Novara Randonee (TankerBelle)
Liked 3 Times in 3 Posts
I helped someone fix a flat the other day that was caused by a tiny pebble lodging itself in the tire. It was JUST pointed enough to penetrate the tire and tube. Once it was pulled out, it didn't look like much more than a largish grain of sand.
"There is no greater wonder than the way the face and character of a woman fit so perfectly in a man's mind, and stay there, and he could never tell you why. It just seems it was the thing he most wanted." Robert Louis Stevenson
bmclaughlin807 is offline
Old 07-07-06, 02:27 PM
MacG's Avatar
MacG is offline
Old 07-07-06, 02:29 PM
Wheee
LilSprocket's Avatar
Bikes: Schwinn Rocket 88 phase 1/ Surly 1x1/Cannondale R700 WSD 650c
I was preparing to leave my house this past Saturday morning.
Was all geared up and ready to go, about 30 minutes prior, I'd pumped the tires on the road rig to the usual 120psi, now was reaching for my socks and BOOM!!
My rear tube blew, right there parked in my living room…
My cat hurled himself through the air and up the stairs, I don’t think he even touched the ground…
poor lil’ guy….
I found no cause whatsoever for the blowout… save for a tiny hole near the valve. I changed it out and rode 40 miles. I suppose better to blow out in the house than on the ride.
A friend suggested it was simply the tubes time…
If you can't be a good example, then you'll just have to be a horrible warning.
https://www.myspace.com/qwtrailbuilders
rip sydney
LilSprocket is offline
Old 07-07-06, 03:18 PM
roughrider504's Avatar
Bikes: bunch of junk
Quoted: 22 Post(s)
Liked 3 Times in 2 Posts
I had a thorn puncture a kevlar MTB knobbie. It looked like a animal's tooth.
roughrider504 is offline
Old 07-07-06, 04:53 PM
45 miles/week
Eggplant Jeff's Avatar
Bikes: Jamis Aurora
I just had two flats in a row. One coming home last night, and the other this morning on my way to work. Same spot in the tire, and almost the same spot on the commute.
I patched it last night on the road, then after I got home and waited a couple hours it was obvious the patch wasn't holding 100% (it was leaking about 5-10 lbs an hour just sitting there). So I changed the tube. I checked the tire and couldn't find anything still embedded in it... but today I got another flat, in almost the exact same spot on the tube. Again I patched it (I think the patch is holding this time) but I really gave the tire a thorough examination. It was slightly rough on the inside where it had been punctured, but still no sign of what caused the hole. I dunno, I guess maybe it was just an "opportunistic" puncture... something happened to come in through the hole that was already there in the tire. Or maybe it's one of those tiny grain-of-sand things, but hopefully in that case the patch will be thick enough it won't give me another hole.
Treasurer, HHCMF Club
Now living in the land of the cheesesteak.
But working at a job where I can't surf BikeForums all day any more...
Eggplant Jeff is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
