Ibike pro
semifreddo amartuerer
Bikes: several
I am pretty sure the OP himself does...and I'm really looking forward to hearing what he says !!
And I'm also taking bets on how long it will be before Squint arrives, trashing anything that is not a SRM Science
Aut Vincere Aut Mori
Bikes: Irish Cycles Tir na Nog, Jack Kane Team Racing, Fuji Aloha 1.0, GT Karakoram, Motobecane Fly Team
Apparently they do not work at all while you're in the draft, as they rely on air passing over/through the meter.
Other than that I haven't heard anything bad...but kinda worthless for getting race or group ride data.
https://www.nyvelocity.com/content.php?id=889
Thats just one. It only makes sense that it wouldn't work well in a pack...
Bikes: several
Originally Posted by asgelle
Do you think we don't remember what you wrote or that we don't know the difference between " wouldn't work well in a pack" and "do not work at all while you're in the draft"?
The article you link to proves the ibike works reasonably well in a pack.
I'm not sure I agree with that, but then again I'm not doing any racing, so ??? My guess would be though that for my purposes, being in the draft or in a pack is a time where I'd probably be the least concerned about my power output...not much you can do about it then so it doesn't matter whether it's more than where you wanted to be or less.
From other reviews and such, the iBike appears to be best on hills and such (makes sense), which, for me at least, is the place I'd be *most* concerned about power (and changes in power).
But I'm in no hurry to pick one up, or any meter for that matter. I think it's still early for this product. I'm going to wait and watch...
more ape than man
i agree. for someone who trains solo this could be a great tool. also, on a solo break or something like that. i could care less what the reading is while drafting in a pack. no tool is going to help you win a race if that's where you spend all of your time.
https://www.cyclingpeakssoftware.com/...gerscience.asp
Bikes: several
But isn't it important to know your true total training load and the correct distribution of your efforts?
more ape than man
a perfect example for me would be doing hill repeats. since i don't use a power meter or ibike i go by precieved effort. the last interval i do is typically much harder than the first, although in reality i'm probably putting out less watts at this point. so, there is a huge mismatch between precieved effort and your actual power output. i think for the average person doing average training this tool would help to gauge your efforts better than just precieved effort or HR.
* of course, i'm only speculating...as i have yet to use one
Guadzilla
Bikes: Pinarello F4:13 W/Campy Reecord & Blue RC6 W/SRAM Force
I realize this is quite old but Im going to bump it back up and make some comments.
First, I know squat about training with power. I bought an iBike as hopes of being able to start training using power as well as gauging my own ride efforts. I had the iBike a few weeks and it has since been returned and a Powertap ordered to replace it.
Why?
Mainly because it's very difficult to get consistent results from the unit. Seems like every time I used it, I had to coast down calibrate it, which is kind of a PITA. You need a long straight road with no traffic to do a coast down and I always ended up having to do several coastdowns before I got a good one. When you go down a hill and the power numbers don't drop to 0, you know you have a bad coastdown.
Also, the tilt calibration is enough to make you want to kill yourself. You put the bike down, mark the spots where the tires are, put it in tilt calibration mode and when it tells you to, you spin the bike around 180 degrees and put the tires back in the same spot. After it finishes the calibration, you can check to make sure you did it right and redo it until you get it correct. My mount was very solid on the bars but I still ended up having to recalibrate it every 2-3 rides.
As far as drafting, in a short paceline, you will defintely see bogus numbers. I could ride behind a few people, check the numbers and just swing the bike out of the draft and the power numbers would jump up. Drop back in the draft and they'd drop back. Supposedly if you're in a big pace line, it's not supposed to be as bad but I didn't get the unit until later in the year and most everyone here has already quit riding so I didnt get to try it in any large groups.
The straw that broke the camel's back for me tho, was the way the iBike performs on less than perfect pavement. Essentially you could stop pedaling on rough pavement and watch the power numbers jump around as you hit bumps. Since I ride in a lot of places with pavement like this, I just decided that the iBike wasn't for me.
Who knows.. maybe with more firmware revisions they will solve some of these problems. I just didn't feel like waiting for them to straighten it out. I also found the companies customer service to be nonexistent. I sent an email before I bought the unit asking some questions and never got a reply. I took a leap of faith and bought one anyway and sent another email asking some technical support questions and again, got no reply.
Hopefully I have better luck with the Powertap.
Why?
Bikes: several
Thanks for your review. Good luck with the PT. I'm still waiting (not necessarily for this, but for something, and probably not a SRM).
Guadzilla
I decided on the PT after watching them on Ebay. You can get new money for a used one and for what I bought mine for, I figured "Why not?"
Guadzilla
What's wrong with that? Seems to me that's how it should work.
The problem is the draft blocks the wind from the port on the iBike and when you slide out of the draft, the wind returns and the numbers spike.
To a certain extent that's true but we're talking pretty dramatic numbers.
Guadzilla
I dont have any of the data unfortunately. I didnt get a lot of useful data logged to begin with because of the constant need to redo the coastdowns. Sometimes I'd have to redo it 2 or 3 times per ride. Most of the numbers I have are just from riding and watching the unit.
It will be interesting to compare it to the Powertap and see how the wattage looks. If it looks similar, Ill go to Performance and rebuy the iBike and do a comparison between the two.
Guadzilla
calibrating the unit seems like a hassle. i don't think i would want to deal with that.
Hmmm...okay, I can weigh in with my experience. It's long, but hey you asked. As always, for the ‘well I never had anybody honk at me when I was riding’ responders, YMMV of course.
For comparison with the iBike Pro, I have a Powertap SL and have ridden a club training tire with a Powertap Pro. I got the iBike Pro as a cheaper alternative to use on my commuter bike, which this time of year especially sees a lot of my ride time. I have always been curious to know how much training stress and recovery impact there is from the two-a-day-all-out-death-avoidance extended sprints that best describe my country-to-urban commute.
I am on my second iBike Pro unit at this point. The first one I believe had something wrong with it out of the box as it ate batteries like The Matrix. You think recalibrating one of these suckers every couple of rides is a pain, try having your unit/CPU freeze up and cut out every couple of rides from a low battery. I returned that unit and got another which I have been riding for a while now. I have gotten somewhat better results, but I definitely suspect these units to be both cold sensitive and comparative battery eaters. After several months of riding with the iBike Pro that is certainly true of my experience when compared to my experience with Powertaps. I will replace my Powertap CPU battery twice, maybe three times a year, depending upon ride and download time, and the hub batteries once a year. With the iBike Pro I am changing the battery at least once every month. In the colder months it has definitely been even like once every two weeks. And on the basis of number or rides, or duration, I can't explain or justify this. As best as I can tell there appears to be a fairly narrow window within which a new battery will put out enough juice to allow the iBike to properly function. Below that, you get either bad ride data or an error message and none at all. The weird part is that I can then take the same battery and pop it into my Polar computer or chest strap and get a lot of use from it down the road. I have done everything that I can think of to improve battery life, right down to removing the CPU from its bike mount between rides, keeping it in doors and out of the cold, etc., with no noticeable improvement. The worst part about this aspect of the iBike experience for me is that as battery life goes, so goes the units ability to hold a calibration and to produce useable, authentic ride data. Many, many, many times I have found myself at the side of the road switching out to a new battery in hopes of getting any useable data from my ride after discovering that I am no longer getting anything but gibberish displaying on my CPU.
As for accuracy and consistency in terms of data, one thing that riding with a Powertap does for you is to give you a really good idea most of the time of how much power you are cranking out, especially in terms of max and average relative to what you are doing and how you are riding. I have ridden my commute with my road bike and Powertap many times to get some general comparison data to use as a guide. For the most part, albeit with this second iBike Pro unit, I am capable of getting decent data read-outs. Part of the calibration aspect of the iBike unit though is to input the exact combined weight of you, your bike and your riding gear, right down to what you will be wearing and carrying on that ride. If you screw that part up, or don't recalibrate your unit when this combined weight and profile will vary ride to ride, you can definitely screw up the accuracy or authenticity of your read outs. So you can skew your data if for some reason you want to, or you can well be getting skewed data and not know it if you skipped the scales and just winged it at guessing the weight. Even calibrations on the hoods versus rides in the drops will give you skewed data. They make all of this very clear in the iBike literature, but it is still an aspect of the unit that bears consideration.
Overall in terms of data authenticity, I have noticed more weird ‘where the heck did that come from data anomalies’ from the iBike than I have ever gotten from a Powertap. You know how with a heart rate monitor electrical interference can give you mystery 225bpm readings? Well the iBike does the same thing a lot in my experience under max efforts. I have seen everything from speed, incline and watts being affected. The unit calibrates and calculates based upon the parameters which include combined weight and are relative to a consistent riding position during the calibration. Stuff like hopping out of the saddle and bursting into a full on sprint seem to confuse the crap out of its little brain. Doing that swinging out of a paceline (or out of the draft of a car as I have frequently seen) can be even more problematic. That is the biggest pain from these units in terms of obtaining reliable training data. When I know at best, I am dialing up to maybe 900 watts at a full on, fully loaded sprint out from a stop light on my commuter...and this is after plenty of comparative efforts with a Powertap...I get home to download my ride to find that I am the new Tom Boonen. Now granted I know that trying to sprint through an intersection before semi hits you is inspirational, but I don't believe that 1300 much less 1700 watt bursts to be anywhere in my repertoire. As a result, for those of you using CyclingPeaks, I’ll bet that I have ended up scrapping a third of my rides because they are skewed by these spikes and mystery data outliers.
Recent firmware updates have definitely taken care of a number of data cut-out, and algorithm funkiness issues that before were known to create this type of anomaly and otherwise mess with the accuracy and consistency of your ride data. Even with the latest updates, I believe these units to definitely still be sensitive to rough road issues. There are miles and miles and miles of lovely Texas chip and seal up in my neck of the woods that will kill your iBike unit data collection and read outs all together for entire extended sections of your ride. On my commute, I notice that data accuracy cuts out over even slight pavement variations, like riding over sections of asphalt on concrete pavement patches or over the bumpy transitions from sections of paved concrete multi-use paths. Stuff like pot holes or rough asphalt that I see along the city portion of my commute wreak havoc on the iBike. Even on perfect pavement, the readings cut out when cornering too. By comparison, none of this will happen with a Powertap. The newer firmware updates to the iBike have been designed in part to compensate for its issues with less than pristine pavement. But these appear to my little brain to be more in the form of how the power algorithm compensates, interprets and extrapolates for the gaps in your ride data than of truly eliminating the unit's sensitivity to bumps and variations over the road. This is a unit that requires a rock sold mount to your bike, right down the foam adhesive strips that are included in the install elements that come with the unit.
The other big let down with the iBike for me has been in terms of ease of use, and usability over the road. Maybe it’s just me, but I find the Powertap CPU to be psychotically easier to access and manipulate. The five point rocker switch approach utilized by the iBike doesn't really work over the road, especially when compared to the one finger or two finger push button approach of the Powertap CPU. And even then, with the Powertap CPU you are talking about only two raised easy-to-locate and manipulate buttons. Recent firmware updates have done some things to improve this a bit in the iBike, but that has been in terms of improved screen prompts and manipulation. The weakness in the unit for me still remains the use of a five point rocker switch. This can be a lot harder to do over the road than you would think by just looking at the unit. It is really easy to hit a bump as you press and find yourself in another ‘how the heck did I get here’ area of the standard read out menu; and the press and hold features can take multiple attempts to complete unless you are doing them over a nice smooth stretch of road with it taking several seconds to find the right portion of the rocker to press and hold.
Another big gripe of mine is that there is not a standard screen readout on the iBike which will display watts, speed and distance or trip time on the same three line CPU read out. You get two basic read out formats: Bike (speed, distance, trip time) and Power (speed, power, calories). You can get to some additional ride data as you can with the Powertap, but there is no way to toggle one of the read-out lines into showing you what you want to see in addition to the speed and power data. (For reference, the Powertap CPU reads top line watts, middle line speed and lower line you can toggle between the other data points like ride time, distance, cadence, heart rate, etc.) There are some bar graphs and pace arrows which may be an attempt on the iBike to supplement this, but they don't do much for me over the road. There is an interval mode approach available on the iBike, but it basically is a specified watt for a specified amount of time preset that you create via your PC before the ride. For me then this means that if I want to ride a ladder of intervals at a certain progression of watts, like on hill repeats or with negative split sprints between stop lights, I can't see a read out that shows me whether or not I am maintaining my watt targets, plus see the corresponding time component. The only approach that I can use is to toggle between the two basic read out screens during each interval. In a word, this blows. In two words, it psychotically blows. Try doing that holding your line in traffic at a full on clip and see if you like it any better than I did. And trying to do the press-and-hold stuff is even worse. Instead of a quick two button snap-shot that you can do by feel with the Powertap CPU, you instead have to do a hold and release approach by pinning down one section of five-way rocker switch to access the iBike's sub-trip capability.
Overall then, I can’t say that I would recommend the iBike Pro, either as a training tool or even on the basis of it being another geek toy for the more money than sense cycling set, of which I would definitely qualify as a member. I have seen on another forum one of iBike’s/Velocomp’s principals say that to date they have only had something like 2 units returned for a refund after the individual has taken the time to properly mount, calibrate and learn the unit. I have to say at this point that I will likely be amongst that number. They are cranking out firmware updates on an extremely frequent basis, the latest and version that I am currently riding is as of last Friday. I will likely give these such offerings a little more time over the road before deciding. As posts here and on other forums will indicate though, there are plenty of those who love these units and say that they are thrilled with them. So again, YMMV. Any differences in expectation and intended useage alone could well account for that.
Apologies to iBike/Velocomp and all if I have misrepresented anything or missed some key function that would have solved one of my issues. But given my uses, ride characteristics and perhaps any limitations as a sincere but knuckleheaded user, the iBike at its best will not be luring me away from my Powertap.
Now I have to go pee.
部門ニ/自転車オタク
Bikes: 2008 Blue T16, 2009 Blue RC8, 2012 Blue Norcross CX, 2016 Blue Axino SL, 2016 Scott Scale, Fixie, Fetish Cycles Road Bike (on the trainer)
My time is worth money, and everything I've read here and elsewhere seems to point to the iBike being an extremely time consuming power meter.
My PT SL took as much time as to mount it in October, and change the batteries last Saturday night.
For the folks that suggest that consistent readings are as good as consistent accurate readings, I say hogwash. Save your money, don't buy the aero wheels cause they look sexy, and put the PT SL on a Mavic Open Pro.
No need for aspirin after any rides, or "coast down" calibrations when you change your underwear.
Envision, Energize, Enable
Had one. Returned it. Why? Even tiny imperfections in the road surface made it loose track of it's intended purpose. Nice measurement idea that would compliment a powertap but why bother. Get a PowerTap or SRM. If you buy the iBike you will be doing alotta calibrating and downloading new firmware and talking on the iBike forum. Essentially, this unit is a beta that is being field-tested by consumers. When vaporware comes to market it is... betaware.
Isaias
Bikes: Ridley X-Fire (carbon, white)
Quoted: 7 Post(s)
