Gear/inch formula
Quoted: 1572 Post(s)
Liked 643 Times
Chairing teeth divided by rear cog teeth times 27.
don't pedal backwards...
Bikes: Surly Long Haul Trucker set up for commuting and loaded touring, old Sekine road frame converted to fixed-gear, various beaters and weird bikes, waiting on the frame for my Surly Big Dummy build
not quite. [chainring] / [cog] * [rear tire effective diameter measured in inches]
27 will only work if you have a rear wheel that rolls as an exact 27 inch circle. A 27" wheel/tire does not have a 27 inch diameter, either. 27x1-1/4 is about 27.1 inches, 700x23 is about 26.3 inches, and 26x1.5 is about 24.9 inches.
Better yet, just use this thing I wrote a while back. It's designed mainly for singlespeed/fixie math, but it's pretty handy overall.
https://www.basementfreaks.com/members/karl/gearing/
Liked 7 Times
Actually Retro's simple formula is plenty good enough because gear inches are normally used to compare various gear combinations so any constant will work. The actual diameter would be important only if you were calculating development, how far the bike travels with each revolution, and then you need to include pi in the formula. By using the generic 27 you can quickly calculate gear inches by hand or on a simple calculator.
Al
Al
semifreddo amartuerer
Bikes: several
OK, if you're extremely anal about it, but:
(39/25) * 27.0 = 42.12 (52/11) * 27.0 = 127.63
(39/25) * 27.1 = 42.27 (52/11) * 27.1 = 128.11
(39/25) * 26.3 = 41.02 (52/11) * 26.3 = 124.33
(39/25) * 24.9 = 38.80 (52/11) * 24.9 = 117.71
With the possible exception of the 26 x 1.5, I'd say RG's formula is quite reasonable for a quick estimate.
My bikes became Vintage
Well, 27" has always been taken to be the rolling diameter of a 27" tire and even for 700c. For road bikes, 27" is good enough, even if it's out by 1/2", because you'll never feel the difference.
And speaking of gearing, anybody here feel at all comfortable with the European concept of "development"? I think they tried to introduce it in Canada some years back, but nobody was having any of it.
Liked 643 Times
Quoted: 2026 Post(s)
Liked 1,096 Times
I also agree that 27" (or 26" for MTB calculations) is plenty close enough for what we are trying to determine. You don't use a micrometer when a yardstick is adequate.
Liked 7 Times
Originally Posted by HillRider
Gear-inches may be archaic but it has an old and honorable history and we all know how to interpret the numbers. That's really all we need.
AL
cycles per second
Bikes: Early 1980's Ishiwata 022 steel sport/touring, 1986 Vitus 979, 1988 DiamondBack Apex, 1997 Softride PowerWing 700, 2001 Trek OCLV 110
Quoted: 44 Post(s)
Liked 71 Times
Videre non videri
Bikes: 1 road bike (simple, light), 1 TT bike (could be more aero, could be lighter), 1 all-weather commuter and winter bike, 1 Monark 828E ergometer indoor bike
Originally Posted by Retro Grouch
Yup. Retro doesn't do the roll out thing to find tire circumference when he's setting up a computer either. Sometimes close enough is close enough.
Quoted: 3450 Post(s)
Liked 420 Times
Using an accurate wheel diameter might be a mute point for most of you but for me I have/had bikes with 3 different wheel sizes so in order to compare gears between the bikes being accurate is important.
700x23c is 26.3", 650x23c is 24.3" and I had a 24" wheeled bike that was 23.6".
Regards, Anthony
Regards, Anthony
Liked 1,096 Times
Regards, Anthony
Regards, Anthony
Bikes: Old Bike: 1975 Raleigh Delta, New Bike: 2004 Norco Bushpilot
Liked 5 Times
Regards, Anthony
Regards, Anthony
Liked 1,096 Times
Originally Posted by Wogsterca
Technically the diameter of a 700x23c tire at 8 bar, and at 9 bar is different, maybe only .5mm but still different.
Wrong Side Of 50
Bikes: Flat Bar Rd 06-105 30s50/39/30 12/25
[QUOTE=HillRider]Worse yet, the Euros express it in Meters so we are even less familiar with what it means in terms of gear ratio and peddling difficulty/bike speed. Gear-inches may be archaic but it has an old and honorable history and we all know how to interpret the numbers. That's really all we need.
QUOTE]
Hi HR & Co
Just a perspective from a relative newcomer to biking, 4 years in fact after a 30 year "rest". Gear inches may be of use to old hands [or more accurately, those that have been around bikes a long time & not metrically orientated] but from my POV the use of "development" is more appropriate. I can easily equate to something that is real i.e. 50/12 X 2115 [tyre rollout of my 25mm] = 8.81 Metres being the top gear rollout of my current bike per crank revolution, compared to 48/11 X 2140 = 9.33 Metres top gear rollout of the old hybrid bike.These would respectfully be 112.5 & 117.8 gear inches. I have my own spreadsheets for the complete gear rollouts of all the common gear ratios for me to compare.
OK, so these gear inch examples will tell me which is the taller ratio, but my metric gear rollout [which is what I call it] is a real measurement compared to just a comparison between figures. BTW I grew up with imperial measurements, so inches themselves are not foreign to me, but after living with metrification for 30 odd years [Australia took the plunge & did it] it is by far a simpler system.
I also like accuracy in the wheel circumference/computer settings scenario, which equates to lots of white paint dots on my driveway, so pi not required Al1943 that's just the way I am, pedantic maybe but I count my air swings in golf as well.
Al
QUOTE]
Hi HR & Co
Al
