Lateral positioning
Bikes: Bianchi San Remo - set up as a utility bike, Peter Mooney Road bike, Peter Mooney commute bike,Dahon Folder,Schwinn Paramount Tandem
Lateral positioning
There is another active thread on Right Turn on Red going on in which some of this is touched on, but something that happened to me on my commute home last night is making me think about how I position myself laterally on the roadway.
On intersections where the right lane allows traffic to either proceed straight, or to turn right, when I am the first at the intersection I position myself such that if a car wants to make a right turn on red, they can get by to the right of my bicycle. Last night,I am doing just this, at a relatively busy intersection, when a black escalade creeps up to my right, I assume to make a right turn - as they approach the limit line, the light turns green, and the car proceeds straight, moving to the left to recenter herself in the lane, and pushing me further to the left, allowing another car to pass me on the right before I was able to assert myself as being clearly in the right hand lane.
I can avoid this by positioning myself to block any and all traffic approaching the intersection behind me, but this seems to be obnoxious to those drivers who do want to make a right on red.
Any thoughts (silly question with this group)?
totally louche
Bikes: the ever shifting stable loaded with comfortable road bikes and city and winter bikes
if theres a car 'creeping' up on my right in a wide lane at a stop, i am going to be very wary of a jackrabbit driver. I try to manuver into primary pole position out of a stop light by 'reading the cross signals' but this is by no means infallable.
its a quantum quandry zone between helping drivers turn right, and preventing jackrabbits on right.
At stops, I take up as much room as possible, asserting my control over the lane. Once the light turns, or I go past the stop sign, I then move over. I like to think of stop signs and lights, as no passing zones. How confident are you that a driver can slide past you at a light to turn right on a red? I am afraid I'll get hit by a mirror or something. But then I also split lanes at stop lights i.e. ride to the front of the line at stop lights, last place I want to be is at the end of a line at a stop light where some idiot will run up on me and hit me. I can here it now " Officer, I didn't even see him" as the ambulance approaches.
I remember a thread on the identical issue/question a year or two ago. Maybe it was in the commuter forum. At any rate, I have the following comments/suggestions.
- if you pay attention, you can usually figure out if they're planning on turning right or passing you on the right and continuing to go straight. Looking back to check out their faces and to make eye contact can be very helpful for this, , as well to make sure you're humanized in their minds. Also, looking at their front wheels can help.
- It's really not a big deal when they do it.
- usually there is a sweet spot that makes it clear you're allowing right turners to pass you on the right, but not through traffic. If you move left of that sweet spot, then you're just staying out of the way of everyone, and they act like you're not even there.
Been Around Awhile
Bikes: Vaterland and Ragazzi
Bikes: 1983 Trek 500, 2002 Lemond Zurich, 2023 Litespeed Watia
I stop near the center of the lane like I would in my car. This indicates my intended destination. If a driver approaches behind me, I look back for a turn signal. If they signal right, and the lane is wide enough for them to pass safely if I move left, I move my bike left after they have slowed down or stopped. I make it obvious that I am doing it as a courtesy while still intending to go straight.
Dominatrikes
Bikes: Catrike Pocket, Lightning Thunderbold recumbent, Trek 3000 MTB.
In similar situations I will turn around and look the driver in the eye, look at their turn signals, make it obvious I am looking for what their intentions will be. Most of the time they'll "get it" that I don't want them to do any funny business to me. I might even simply tell them what my intentions are sometimes, too.
The other thing I do, if I know the light well, is get a head start before the light is actually green so that I'm well on my way before the drivers are. Probably not quite legal, but definitely safer than becoming a sitting duck in a potentially bad situation, especially if that bad situation is caused by driver error or bad infrastructure.
I would consider these two tactics to fall under the "art of urban cycling" category, not the "VC/Forester worship" category.
Been Around Awhile
Originally Posted by I-Like-To-Bike
The light jumping technique is also the safest way to handle the right lane straight through motorists that I described several posts back. I did it at lights I didn't know also, because I do know the bad habits of city drivers in a rush.
When this kind of unlawful passing happens, I usually am starting near the center of the lane and have plenty of room around me to negotiate space - more than when I am in my car. Fortunately these drivers' intent is obvious before it's too late for me to avoid them by braking or, occasionally, moving a bit left.
Once I learned better, I stopped.
Bikes: Trek 520, Gunnar Rockhound, Kona Explosif (ss),
On intersections where the right lane allows traffic to either proceed straight, or to turn right, when I am the first at the intersection I position myself ,normally, right where I would be if it weren't an intersection ie a comfortable distance out from the curb. The exception would be if the lane is really wide in which case I would stay further to the left, normally far enough that a car could make a right turn to the right of me.
( slightly off topic...We have an interesting intersection here with two lanes of traffic making a left turn and the right-most of those lanes also going straight. At that intersection I sit right in the middle of the right lane and block. And I stay there until I'm clear of the intersection.)
It isn't perfect 'cause cars turning right do try to get by on your left occasionally. Ok, almost always. If it's obvious that they are turning then if there's time left on the light I just let them go without changing my position. If the light is about to change then my actions would depend on whether I think they are an aggressive or passive driver. A passive driver and I would try to show my intention of moving forward through the intersection as the light changes. I don't know quite how to describe it but think eye contact, body position on the bike, jumping the light slightly etc. Most passive drivers are not trying to beat you through the intersection, they are just making a right turn on red 'cause in their minds that's what you do at a red light. If it's obvious to them that they should wait, then they will. An agressive driver wants to beat you through the intersection, couldn't care less that you were there first, and considers it only an inconvenience if you are under their car as it turns the corner, so I find it easier to let them go. I consider any driver who is using a right turn lane to jump the queue and continue straight ahead to be an aggressive driver ( and I agree, they are a big problem ). My opinion on jumping the light when you are alongside an aggresive driver is that s/he will be jumping the light too, and I don't want to be alongside them when they do.
Them's my thoughts.
Cheers, Dave
Them's my thoughts.
Cheers, Dave
Been Around Awhile
Originally Posted by sggoodri
Another strategy is to move a little slower, and let them go ahead with plenty of room.
Bikes: 2016 Hong Fu FM-079-F, 1984 Trek 660, 2005 Iron Horse Warrior Expert, 2009 Pedal Force CX1, 2016 Islabikes Beinn 20 (son's)
I've found there is little one can do to keep motorists from attempting to pass in these situations. My strategy is to position myself as best I can to show my intended direction and to always expect people to try and get around me illegally if they think they can fit. The worst situation I have ever been put in by a motorist doing this is having to slow down slightly. Where it really bothers me is when I am moving at full speed and a motorist decides to pass on my right using a right turn lane at full speed. Way too many things that could go wrong in that situation. I've yet to find a way to curb that action either and just ride defensively through intersections and watch my mirror.
My experience cycling in Philly is that a gap that would be 2 feet too small for a suburb driver to attempt to get through is fair game for a Philly driver. Drivers in the city are just used to cutting things closer.
A bigger problem in my city riding experience (at least in Phila.) is waiting at a light in the first lane left of a right turn/bus stop/parking lane. Guaranteed, someone will use the right turn lane or any available open space to go straight to pass a cyclist (or a motorist) waiting in the thru lane; at every traffic light.
-- I speak for myself only, not LAB or any other organization of which I am a member.
Bikes: 1980s 15 speed road bike, and 21 speed, Iron Horse Outlaw mountain bike and 24 speed Felt F90 road bike
I do the same. The driver has to stop behind me and then I will move over if I feel it is safe for me and the light will stay red for a significant amount of time.
No-Pants Island
Bikes: 2007 Trek Pilot 2.1 WSD & 2001 Specialized Crossroads
I'm experimenting with this situation myself. I tend to to pull up into the crosswalk but in the middle of the lane. There's enough room for cars to turn right, but nobody going straight can pass me.
Two problems with this, though:
1) This is the Bay Area, where people ACTUALLY STOP at the first crosswalk line, if not a little before it. Nowhere else have I ever witnessed this.
2) When you pull into the crosswalk, you risk pissing off (or to put it nicely, obstructing) pedestrians. That ain't cool. Depending on the ped, I think it can be mitigated by saying hi and smiling, or at least acknowledging you see the peds and aren't just blocking the crosswalk oblivio-style.
As for the Mlle. F'quetarde in the Escalade ... let's hope they're a rare exception.
totally louche
i used to 'hop the lights' more than i do now, but did it right in front of a motorcycle cop once and he pulled me over.
however, i 'read the cross signals', treat the traffic light like a skijump timing christmas tree, clip in and stand just prior to the greens, and dont move into the intersection until a) the light goes green and b)cross traffic has cleared. as soon as this is good, i put the hammer down.
even giving drivers the fairness of the traffic signal, the weight/ hp/ torque disparities between bikes and gashuffers is readily apparant as i clear a half to two full city blocks, often, before traffic catches up. i'm talking like a quarter mile in front sometimes, even on a 35 mph 4 laner.....
i can't make hide nor hair of helmet heads comments cars cutting him off with a jackrabbit start and violating his lane position 'isn't that big of a deal?' why is that, are you off in the gutter so it doesn't affect your line, helmie....or do you mean you find traffic close passing you on the right relaxing now, so this doesn't let cars creep up on your right and try to pass you at the lights?
Planet Saver
Bikes: Cannondale CAAD-10, Novara Randonee, Raleigh Super Grand Prix, Schwinn Mirada Sport winter beater
genec
I also stop behind traffic rather than filter forward... I have found very little reward in filtering forward.
A bigger problem in my city riding experience (at least in Phila.) is waiting at a light in the first lane left of a right turn/bus stop/parking lane. Guaranteed, someone will use the right turn lane or any available open space to go straight to pass a cyclist (or a motorist) waiting in the thru lane; at every traffic light. It is immaterial where the cyclist locates himself in the lane; if there is room to the left or right, legal or not impatient motorists will use it to pass. Also applies to motorists using left turn only lanes to go straight through the intersection in order to gain a few places by passing. HH's mumbo jumbo voodoo is worthless in such situations.
In a similar vein, I saw a driver cut off a police cruiser, turning left in front of the cruiser going straight, all the police officer did was honk at them. What am I paying those guys for again?
I don't do the light-jumping thing because I almost got hit by a fast-moving motorist from my left who was thinking along the same lines. Around here, I expect there to be someone whose yellow light becomes red before they cross the intersection.
No worries
No worries
Robert
feros ferio
____
* Fortunately, I have been "right throughed" only twice in 100k miles / 160k km of cycling.
Been Around Awhile
Originally Posted by RobertHurst
Freelancing like that can help a bit, but it can also put the rider afoul of other road users who are attempting to use that gray area in the signal cycle to their own advantage.
Been Around Awhile
