Should I carry a cable cutter on tour?
Old 07-21-06 | 08:47 PM
spinnaker's Avatar
Every day a winding road
I plan to carry some extra items like cables, spokes etc. What happens if I need to replace a cable? Should I carry a heavy cable cutter or just wrap up the excess until I find a bike shop?
spinnaker is offline
Reply
Old 07-21-06 | 09:27 PM
Bikes: Trek 7300FX, Lemond Sarthe
I think you answered your question. I have in the past carried a small pair of pliers that weighted about 85 grams and had side cutters. I seem to remember them being useful, but it escapes me as to what I did with them?
bccycleguy is offline
Reply
Old 07-21-06 | 09:30 PM
spinnaker's Avatar
So just wrap up the excess?
Reply
Old 07-22-06 | 04:00 AM
20 Anniversary
I carry a leatherman mini tool with pliers and wire cutters. It works pretty well but you can just tie off the extra length until you come to the next garage.
I used to carry a pair of needle nosed pliers which were quite handy.
MichaelW is offline
Reply
Old 07-22-06 | 07:26 AM
That's what I would do, just tie it on somewhere out of the way.
Reply
Old 07-22-06 | 07:34 AM
Monoborracho's Avatar
20 Anniversary
Bikes: More than I really should own.
Ditto on the leatherman, in addition to a mini tool, and a small crescent, and a spoke wrench.
Monoborracho is offline
Reply
Old 07-22-06 | 07:50 AM
spinnaker's Avatar
Have the spoke wrench, I have a leatherman knock off that I already plan to bring on the ride. My multi tool has a spoke wrench and Allan keys. I will probably carry extra Allan wrenches as the ones on the multi tool don't have much reach.
Reply
Old 07-22-06 | 08:46 AM
Someone wrote once that a spoke wrench is the cheapest and quickest way to put your bike out of commission that there is. Learn to use it before you need it!
I don't carry all those "multi-weights" because they are heavy and often poorly suited to the job. Take an inventory of exactly what size hexes, etc. that you need and only carry them. Often the multi-tools are too fat to work well in tight spots and you can't expect to get much leverage on say a 6mm hex with a 2" throw. Try tightening up a crank with a Topeak Alien.
Reply
Old 07-22-06 | 02:09 PM
once I used a pair of toenail nippers.....they were not much good for toenails afterwards but they did get the job done...I now carry a mini-leatherman...that has been useful for many tasks
fsor is offline
Reply
Old 07-22-06 | 06:28 PM
supcom's Avatar
You need a new bike
20 Anniversary
If need be, you can buy a pair of diagonal cutters in any hardware store. You could also probably get someone at a garage to cut the cable for free. You don't need special cable cutters to trim the end of a bike cable.
supcom is offline
Reply
Old 07-22-06 | 09:55 PM
kesroberts's Avatar
20 Anniversary
Bikes: Several
I learned the hard way (but not on my bike fortunately) to cut off the unneeded end of one of those cables that has two different heads before leaving home. (does that make sense - I mean on of these: https://www.rei.com/online/store/Prod...jpg&view=large)
kesroberts is offline
Reply
Old 07-28-06 | 08:38 AM
accidental tourist
Take a look at the small Vise-grips that are available. A Vice-grip tool is a useful emergency tool that can deal with rounded or frozen fasteners, act as a clamping device to hold broken parts together, and cut cables better then any Leatherman or multi tool. Down by the pivot of the jaws is a small anvil and blade cutter that snips cables cleanly and easily.
spokewrench55 is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
