Road vs MTB Helmets
cheap for a roadie
Bikes: Ridley Excalibur, Ridley X-Ride, Trek Superfly Elite AL, KHS Flite100
Road vs MTB Helmets
Is there really that big of a difference? Are there any defining features or is it mainly marketing and styling with maybe a little better aerodynamics and perhaps ventilation on the road helmets?
Faster but still slow
Bikes: Trek 830 circa 1993 and a Fuji WSD Finest 1.0 2006
Hmmm, never knew there was ever a distinction. It looks like those marketed as MTB helmets just have a visor.
Bikes: Bruce Gordon BLT, Cannondale parts bike, Ecodyne recumbent trike, Counterpoint Opus 2, miyata 1000
If you mean those whole head helmets used by downhillers there is an obvious difference. Other than that I have not seen a significant difference in 90+% of the helmets in the unsolicited Nashbar and Performance catalogs I keep getting. I prefer a hard-shell as it is easier to attach a mirror to one.
Cycling Skier
Bikes: 2019 Moots Vamoots DR, 2008 Pedal Force ZX3, 2006 Jamis Eclipse, 1997 Marin Indian Fire Trail
There's a bit of a difference in design between road and MTB helmets from Giro. The difference has to do with the design of the vents.
On Giro road helmets, the vents are designed to be used at speed: drawing air in, moving it over the head to cool, and allowing for easy exhaust from the back. There are very few squared-off vent openings on Giro road helmets, as they want to allow air to enter from the front of the helmet as the rider moves forward.
On Giro ATB helmets, the vents are optimized for low-speed operation, where a lot of cooling involves radiation of heat without the aid of high-speed forward movement. Thus, the vents tend to be more squared-off. Additionally, there tends to be more foam/shell surface area on ATB helmets (especially ones aimed at the freeride set) to help protect against penetration from sharp objects (e.g. rocks, stumps, etc.).
Where you'll see more similarity is amongst helmets aimed at the ATB XC racing set, who are usually moving at a speed more akin to road riders - thus, the reason that the Bell Sweep XC is essentially the same as the Sweep R road helmet, the only difference being a visor. But for the less-speed-oriented ATB set, you'll tend to see the squared-off vent openings.
There's a similar design philosophy for Bell, MET, Rudy Project and Specialized helmets, too: bigger, more aero-designed vents for road-oriented helmets, more foam area and squared-off vents on ATB helmets.
