Bottom Bracket Size
Hopeless Romantic
Bikes: 2005 Soul Cycles Loki; 1987 Schwinn Predator
Bottom Bracket Size
I've searched and I can't find an answer to this. my current frame has a 68mm bottom bracket shell and I'm going to a frame with a 73mm shell. I believe I need a new bottom bracket that is 73mm, but to keep everything else the same, do I need to get a different size spindle as well? Like if I have a 68, 113, do I get a 73, 113 or does it need to be larger because of the larger shell?
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times
You won't need a new BB if it is a 'universal' one - - it should say 68/73 if it is. A lot of Race Face BBs are both; a lot of FSAs are one-width-only. Pull your BB and look at its markings; or if you know the exact model, look it up on the company web site.
Should not need a longer spindle; 68/73s are made for the wider width. The non-drive-side cup just screws in farther to fit a 68 along with a drive-side spacer.
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
Bikes: Lots
Stick with a 73x113. the 68 or 73 denotes the bottom bracket shell width. The 113 denotes the spidle width.
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
"Your Bike Sucks" - Sky Yaeger
Hopeless Romantic
Thank you both. I wasn't sure if I needed a wider spindle for the wider shell or not.
