Anyone using Take-Offs?
I have a question for you.
I can't for the life of me figure out what I need to connect the cable housing to the old downtube shifters location (secure the housing to the downtube).
If you can, take a closeup picture of where your old DT shifters were. I don't think I have the device needed to connect it, and I need to find out what I need to buy.
I ordered from eBay, so it was just a generic kit.
I've been trying random things (using zip-ties mainly), and have been unsuccessful for literally days.
PM me or post in here...hopefully I get a response quickly.
cyclist/gearhead/cycli...
Bikes: Homebuilt tourer/commuter, modified-beyond-recognition 1990 Trek 1100, reasonably stock 2002-ish Gary Fisher Hoo Koo E Koo
Do you have bosses on your downtube? Those are brazed-on things that stick out and have threaded holes that a shifter can attach to.
If so, then what you need are these: https://www.loosescrews.com/index.cgi...id=27640726492
They attach to the shifter bosses and provide cable stops and adjuster barrels. The curved ones are very nice if you have a 1-1/8" downtube. They look very nice and blend in smoothly with the downtube. The $15 price is annoyingly high for such simple things... I got mine at a swap meet for $2 or something.
Death fork? Naaaah!!
Scroll down this page until you find housing stops:
https://sheldonbrown.com/harris/cables.html
I think what you want are Shimano cable housing downtube stopos.
Top
Top
Top
Top
This is what they look like. Shimano works with Campy on this, right? (I don't see how it wouldn't, but just want to be sure)
Aha! You have *clamp-on* downtube shifters. So what you need is a clamp-on downtube cable stop. They are also sold by Harris: https://sheldonbrown.com/harris/cables.html ... scroll down until you see this picture:
These are fairly ugly and $12 is quite expensive. I have several of these lying around in my basement, and they are of a much nicer low-profile style. If you tell me what the diameter of your downtube is, I can find one that fits and mail it to you.
Originally Posted by biolife
Is that the only style that will fit my bike?
I'll figure out the diameter.
Ah, I see.
Look for a Sun Tour or Shimano cable stop for barcons or stem shifters.
Worse case, you can dismount the shifter levers you have and drill the bosses. Drill a hole small enough for the cable all the way through, and counterbore it from the top halfway through big enough to take the cable housing. ugly, but it works.
Top
Top
Liked 6 Times
From the picture of the bike, it appears to me that he's got standard downtube shifter braze-ons, so I think you guys were on-target the first time by suggesting the Shimano stops from Harris and LooseScrews. Look again at his photo; there's no metal band around the frame, those shifters are on regular shifter studs.
On to the bigger picture: biolife, what mixture of shifters, derailleurs and rear cassette/freewheel are you brewing up? ...to address the question of whether it's all going to work together or not.
On to the bigger picture: biolife, what mixture of shifters, derailleurs and rear cassette/freewheel are you brewing up? ...to address the question of whether it's going to work together or not.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
It's all Campy Nuovo Gran Sport.
Here are some crappy camera phone pics.
The digital camera isn't charged, so this is the best that I could pull off.
It juts out from the frame.
This is the little piece that is normally glued on there, but it came loose. On the other side it's still stuck on.
Liked 6 Times
Ok, get a set of those Shimano cable stops that the guys linked to. Take the little piece off the other side, you won't want it on there when you have the Shimano cable-stop dealiebobs. The little piece is part of your shift lever, not part of the frame.
Your local bike shop probably has a set of the Shimano cable stops lying around that they could sell you, if you want to get along with your project right away.
