Grease for headset/bottom bracket?
cyclist/gearhead/cycli...
Bikes: Homebuilt tourer/commuter, modified-beyond-recognition 1990 Trek 1100, reasonably stock 2002-ish Gary Fisher Hoo Koo E Koo
White lithium grease works great (available at any auto parts store or hardware store). I've been using it for years with good results.
Many knowledgeable BF members prefer marine wheel bearing grease (used for boat trailers, and therefore designed to be highly waterproof), which a boat store would have, and a hardware store or auto store MIGHT have.
lawkd did some actual research into the quality and properties of various greases and decided that marine wheel bearing grease is as good as, if not better, than expensive bike-specific grease brands (such as Phil Wood and Pedro's). I can't find that thread, but it was recent...
This topic is one that has provoked many mindless flame wars on bikeforums. Hopefully I've included enough balance in this post to avert that?
Old biker
Bikes: Custom Cammack touring road and 1987 Fisher Hoo Koo E Koo
Bike bearings are so lightly loaded compared to auto bearings that almost any grease will work OK. I just use what ever automotive wheel bearing grease I have in my shop.
Originally Posted by ASU
thanks mox. should i look for the White lithium grease in a tube/can or what? thanks again!
Personally I prefer the toothpaste-style tubes, since they dispense the grease in a convenient way while preventing dirt from getting into the container. The cans do have an advnatge though: you can dip in a painbrush and apply grease to a seat tube or stem or bolt that you're trying to grease up, which is very convenient. But cans of grease tend to collect dirt, which isn't good when you're going to use it on bearings.
Bikes: Old Bike: 1975 Raleigh Delta, New Bike: 2004 Norco Bushpilot
Originally Posted by moxfyre
You can get it in several different forms: toothpaste-style tube that you can squeeze by hand, cartridge for a grease gun, or can.
cab horn
Bikes: 1987 Bianchi Campione
I used to use a popsicle stick, to dump some grease on a margarine tub lid, then apply from there, since the first stick,
Originally Posted by mechBgon
Tangentially, if you ride in nasty conditions, a Lizard Skins Headseal might be worth getting.
Any grease is overkill for a bicycle for the reason Charles states. Having said that, I use CV joint grease because its cheap and comes in a tube, which is a lot handier than the tub O' grease.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
34x25 FTW!
Bikes: Kona Jake, Scott CR1, Dahon SpeedPro
I have the white lithium stuff in a spray can (!) and a tube. I'm afraid of bearings, though, so I can't say how good it is for those sorts of applications.
(I use it on threads and such)
ride, paint, ride
Bikes: Cannondale R300 Caad2
Bicycle grease still needs to be chosen for maximum waterproofness, since bike bearings aren't as well sealed as car bearings (better seals add weight and drag). Also, for those who may ride in cold climates, LOW-temperature viscosity is important!
