Go Back  Bike Forums > Bike Forums > Recumbent
Accessories on USS
Recumbent What IS that thing?! Recumbents may be odd looking, but they have many advantages over a "wedgie" bicycle. Discuss the in's and out's recumbent lifestyle in the recumbent forum.
Accessories on USS
Old 03-10-03 | 01:05 PM
20 Anniversary
Accessories on USS
Hi all,
Where do you put accessories such as lights, computers, water bottles, etc. on recumbents with USS.
I am looking at buying my first recumbent and like USS but also like gadgets. I don't think I have seen any accessories on pictures of bents with USS.
Thanks
Ron
RonV is offline
Reply
Old 03-10-03 | 02:01 PM
mtessmer's Avatar
Bikeman
20 Anniversary
Bikes: Many
When I had my USS I mounted a "T" piece in the front shifter tube. I just went to the hardware store and bought a plastic PVC "T" (1 inch), took the cap off the tube, shaved the plastic a little, applied a little Goop (glue), stuck it in, put bar end caps on the two remaining openings. I was able to mount a computer and a light. It worked great, it never came loose.
mtessmer is offline
Reply
Old 03-10-03 | 06:42 PM
bentbaggerlen's Avatar
20 Anniversary
I mounted a head light on the boom tube of my R-40, used a moped mirror on the USS handle bar as well as the computer. I have also seen GPS units mounted to the derailer tube on SWB/USS bikes.
Bentbaggerlen
"When the spirits are low, when the day appears dark, when work becomes monotonous, when hope hardly seems worth having, just mount a bicycle and go out for a spin down the road, without thought on anything but the ride you are taking." - Arthur Conan Doyle
bentbaggerlen is offline
Reply
Old 03-10-03 | 08:37 PM
RHNiles's Avatar
20 Anniversary
Bikes: Surly LHT, Raleigh Pro, Cannondale R4000, RT1000, Rans V-Rex Bent, Spec FSR Pro
I ride a Rans V-Rex but I mounted a Minoura Space Bar on the top of my Der. Tube for extras such as lights and speedo. On the tube, I had to cut about a 1/4" off so the cranks would miss it, but it has turned out great. I leave it on all year long because it is not in the way or even noticable up there.
Rick
RHNiles is offline
Reply
Old 03-10-03 | 10:15 PM
20 Anniversary
Vision makes a part - LM40 - t-shaped & goes in the der. tube. It fits my V-Rex. I got it to mount a headlight. Would also hold a computer if you could see it that far away. Check the Vision web site. A local bike shop - The Silver Comet Depot near Atlanta had it in stock.
Clark is offline
Reply
Old 03-29-03 | 06:01 PM
20 Anniversary
I have a Vision R44 that was originally set up with USS. I have recently switched to OSS but when I had the USS set-up I first used a T-Bar made by Vision for mounting the light and computer. The T-bar mounts in the derailleur tube. This worked well until I installed a fairing. The mounting hardware for the fairing also inserted into the derailleur tube so I had to switch to a Minoura Space Bar which I fastened around the tube on the outside. I could have gotten a long wiring harness for my computer and mounted it on the fairing but to remove the fairing and ride without it, all I had to do was loosen the stem bolt on the hardware and remove it. With the long wire I would have to take the computer off and re-mount it.
As for the light, I decided it was better to switch to a helmet mount so it would shine over the fairing instead of through it. This worked well and I could see my instruments at night as well. I got a bar mount for my HRM and put it in place of the light mount on the Space Bar.
For hydration, I first used a Camel Back pack but I just didn't like the bladder-type set-up so I got some Minoura bottle cage mounts and mounted them on the seat frame facing the rear of the bike. They were back far enough that I could still reach them easily but they didn't interfere with my steering.
For a mirror, I tried several handlebar-mount types but they had limited range since they were so far from my eye. I then started using the clip-on type mirrors that attached to glasses or helmet. I found the best one for me was the Take-A-Look clip-on. It stayed put and had good view.
Most of this has changed now since I switched to OSS and, as always, your mileage may vary.
Arnold Layne is offline
Reply
Old 03-31-03 | 03:20 PM
20 Anniversary
Thanks for all the replies.
Someone convinced me that USS was probably not a good idea for a newbie.
Last week I got an EZ-1 and am enjoying every minute on it.
Ron
RonV is offline
Reply
Old 04-09-03 | 08:31 PM
20 Anniversary
Ron,
The best $ you can spend on your EZ-1 is to get some high pressure tires if you are riding the lower pressure ones now. You will see a big difference. I ride my V-Rex with a friend on an EZ-1 - I would roll down hills much faster than him, even with his fairing, until he replaced his tires and now we are pretty equal, or he may have a slight advantage.
Clark is offline
Reply
Old 04-10-03 | 09:55 AM
20 Anniversary
Clark,
Thanks for the tip. Do you have any models to recommend?
Ron
RonV is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
