Steel frames & Winter cold?
These go to 11.
Bikes: 06' Trek 7.5 FX, '09 Dawes Steel SST
I just bought a new steel frame road bike as an additional commuter. This bike will be for dry conditions only as in no rain, sleet, hail or snow. Do I have to take any kind of precautions with the frame due to "outdoor cold, indoor heat, outdoor cold & indoor heat cycles? Leaving the bike outside is not an option.
I've heard of people saying to spray WD-40 or Frame Saver. Should I buy the Frame Saver?
Melancholy is incompatible with bicycling. ~ James E. Starrs
King of the Hipsters
Bikes: Realm Cycles Custom
I use framesaver on all my bikes.
I don't worry about the heat-cold cycle with tig-welded or lugged frames, but if I had a fillet-brazed frame I could get paranoid about it.
Bikes: Pugsley, fixie commuter, track bike
If you are only riding in cold dry conditions with the bike then nothing extra is needed. But how many winter days do you get that there is not atleast melting snow on the roads. I think atleast some WD-40 in any frame tubes you can get too would be a good idea. Especially around the bottom bracket. I would also suggest removing the seat tube and bottom bracket and reinstalling them after a good application of grease. The biggest long term problems with steel frames in the winter is having one of those two parts becoming stuck due to rust.
Craig
Craig
