Suugestions to Make a Decal?
Baby it's cold outside...
Bikes: Trek 5000, Rocky Mountain Wedge, GT Karakoram K2, Litespeed Tuscany
Any suggestions on how to make a replicate frame decal with standard office equipment... ie Inkjet Printer?
I have a new Tubing decal, and I thought before using it, I would like to try to make a copy of it first and maybe print it on sticker sheet paper.
I looked into this once and I found a place on the net that sells a clear plastic sheet that you can put into a printer that can then be transfered to a bike. Can't remember the website, sorry.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Junk Collector
Bikes: 1987 Schwinn Circuit, 2012 Colnago M10, 1990 Schwinn CrissCross
Quoted: 34 Post(s)
Try here:
https://decalpaper.com/inkjet.html
I have used this before, and it performs very well. Once printed, just spray some light mist coats of clear enamel over it, and you're good to go.
Or you can contact Mike at
https://home.comcast.net/~velographic/VGhome.htm
He does fantastic work.
holyrollin'
There's a procedure at https://www.jalopyjournal.com/forum/s...ead.php?t=8313
Also, I've seen samples of Velographic's decals here before...VERY impressive.
Decrepit Member
Originally Posted by duane041
Try here:
I had great results using a standard color laser printer. Using the laser printer and decal paper instead of inkjet printer/decal paper, the clear enamel coat to prevent smearing isn't required.
Yet another vegan biker
Bikes: Sakae Prism, Vintage Fuji bike(S), too many bikes, one from scratch bike.
Thanks for the links! I've been stripping a frame all day and was wanting to make some decals.
Junk Collector
Quoted: 34 Post(s)
Originally Posted by Scooper
I used the Bel (decalpaper.com) laser printer decal paper to reproduce the Reynolds 531 sticker on my chrome Paramount (the original was scraped off in several places).
Decrepit Member
How did you get it gold? That's pretty impressive.
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 530 Post(s)
Liked 1,004 Times
I have seen decal material for computer printers at a hobby shop that specialized in radio controlled airplanes. One problem with inkjet printers is the colored ink does not stand up to sunlight very well. Certain colors are worse, like red. Black doesn't seem to fade at all.
The decal paper comes in ink-jet and laser types. Ink jet ink is water soluble, and the color will run if the protecting clear coat gets scratched at all. Laser colors do not suffer from this disadvantage.
Copy centers should be able to copy onto the laser decal paper if you can provide them with a good master and the laser type decal paper.
The other thing to consider is that the decal paper comes in white (which is not transparent) and produces an opaque image the size of the decal, or transparent (which lets the background color show through). If the decal os solid colors, or contains any white, you should use the white paper.
-a.
-a.
Decrepit Member
Originally Posted by ViperZ
You guys are the best... Thanks!
Here is another I'll make as well.
Viper, one thing I remember reading on the Bel website (but can't seem to find now) is that if you're printing a decal with white in it, as your Columbus images have, they recommend using an ALPS printer. Otherwise, the white areas print as transparent, not white. I guess you could paint the decal area white, wait for the paint to cure, then apply the decal over it.
-a.
Decrepit Member
Originally Posted by ajf
Chrome Freak
Bikes: 71 Chrome Paramount P13-9, 73 Opaque Blue Paramount P15, 74 Blue Mink Raleigh Pro, 91 Waterford Paramount, Holland Titanium x2
Liked 26 Times
I used some inkjet decal stock a few years ago to make duplicate decals for my Raleigh Competition. They were OK when placed over silver paint as I did on one frame, but much less OK on one that I painted a teal color. The decals printed on clear stock were quite transparent and allowed a lot of the underlying color to show through.
1971 Paramount P-13 Chrome
1973 Paramount P-15 Opaque Blue
1974 Raleigh Professional Blue Mink
1991 Waterford Paramount
Holland Titanium Dura Ace Group
Holland Titanium Ultegra Triple Group
Bikes: '62 Peugeot UO8, '63 Schwinn Superior, ;72 Peugeot PX-10, '74 Motobecane LeChampion, '74 Peugeot UO18
Inkjet Decals
Here's an inkjet waterslide decal I made for my Motobecane Le Champion. It's printed on white waterslide paper and sprayed with clearcoat enamel.
