Embarrasing Question
Bikes: Vintage Raleigh Ladies Racer
How do you work the gears? My son and his friends all have twist grip gears so they don't know. At the moment the bike is in 1st gear and I would like to be able to change gear. It is a vintage Raleigh Ladies Racer mixte frame (c. 1980's) with 5 speed Huret gears. Here is a pic of the gear lever.
Sorry this is such a silly question
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
You should be able to pull the lever toward you and shift.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Bikes: Steve Bauer Whirlwind, Nishiki International, Rocky Mountain Element 30 1984 Cinelli Super Corsa w/Campy 50th, Surly LHT.
And if you can't pull it towards you, it is probably because the inner cable is seized and needs replacing or because that little plastic nut is too tight.
I have the same set-up with the left lever for 10speed schwinn circa 90's, it looks like you have better tape on the handles. I would do as the above poster suggested and lube the cable with some oil or mess with the fastener on the lever if it's stuck.
Bikes: Peugeot Hybrid, Minelli Hybrid
you pull it towards you to get into a lower gear. There isnt an exact position where it shifts you have to move it so the chan runs quietly around the cogs. If the gear moves to a higher gear all by itself you need to tighten the plastic nut in the middle.
So basically it's guess work? You move the lever and the chain moves to a different gear and there's no set position on the lever to correspond with which gear?
I know with my son's bike (twist grip gears) you just keep pedalling and change gear. With the gears on my bike, do I stop pedalling when I change gear?
I know these are probably daft questions, but I don't want to end up damaging my bike. Thanks for your patience
No click stops here! You may have to overshift a tad, then pull back to stop any chatter. Pedal as you shift.
Quoted: 2952 Post(s)
Liked 3,106 Times
No, you have to keep pedaling. "Changing gears" means that the chain will be moved from one cog to another. On your rear hub, you'll have a spring loaded mechanism with two small jockey wheels called a derailleur. See how the chain is threaded around the cogs on the hub and through the jockey wheels? The lever in your picture above is attached to a cable, the other end of which is attacehd to the derailleur. When you push or pull the lever in the picture, you'll move the derailleur in or out, thus "derailling" the chain from one cog to another.
Scott
Bikes: Too Many
I actually prefer friction shifting with a good compensated shifter. A compensated friction shifter has an internal spring that levels out the pressure of the spring in the rear derailleur so the shifter requires very little friction to hold it in place.
You always pedal when shifting gears with all derailleur-gearing systems.
Thank you all. That answers my questions. The derailleur is a little stiff with lack of use so probably needs oiling.
Don't oil the shifters!! Or else you will lose the friction-shift function.
The derailleur only needs drops of oil on the pivot points around the cage (4 of them). If there is trouble shifting, it is likely the galvanised wire cables have corroded inside the sheathes and need replacing.
Thanks for that. I haven't oiled anything yet (had to do some housework which has been sadly neglected in favour of the bike for the last couple of days ). I'll make sure only put a drop of oil on the pivot points. I some suspect the cable might have to be replaced.
