Nashbar Cargo Trailer
How long has Nashbar had a trailer ?
Doesn't look like it hauls as much as a Bob but not a bad price.
https://www.nashbar.com/profile.cfm?sku=18733
Not sure what to make of it. The 45lb weight limit is a bit worrying, though. The BoB Yak, the closest model to this one, weighs in at around a pound heavier, but has a 70lb weight capacity. The difference may well be in the hitch systems -- the Nashbar one looks to create a fair degree of leverage on the dropouts, whereas the BoB one keeps its stress well inboard or close to the dropout.
Still you get what you pay for, and at less than half the price, the Nashbar deal might be too attractive for some. For touring, I wouldn't consider it. For commuting for shopping loads, the weight capacity limits it, and for 45lbs I would use panniers.
Bikes: Jamis Aurora, Fuji S10S (X2), Jamis Coda
I looked into buying a Nashbar and a Bob Yak before I bought a Sunlite trailer for kids and did a bit of conversion. Trek "strongly recommended" that I NOT buy a bike that pulls from either side of the rear axle, ststing that the bike was not designed to bear that type of load at that location. They recommended the type that clamps to the chain guard, and that's what I got.
The Bob holds 70 pounds in addition to the weight of the trailer, so the Bob can hold more. I honestly think 50 lbs is on the lower side to make a trailer useful. In fact, I'm a bit disappointed that the Bob can only hold 70 lbs.
These tests don't necesarilly mean anything. For instance product tests that give a 6 month shelf life may only mean that is how long they tested it for, maybe it lasts for 10 years. We would need a parallel test of each trailer, to destruction. Preferably cycling both really huge loads, and just minor loads over millions of cycles, because the failure modes are different.
Maybe at 50 pounds loading the Nashbar doesn't wipe out bikes.
What you really get with the Bob is the confidence that comes from all the cycle adventures that have been done with it. You know those folks got by with it so you should also.
Thanks for writing. We do not recommend trailer with the carbon frames,
but you can use it with an aluminum or cro moly frame.
Matthew Gutowski
Tech Support
Trek Bicycle Corporation
matthew_gutowski@trekbikes.com
The problems with heavy weight is not so much going uphill, however. It is the desire for the trailer to overtake the bike going downhill. I had the trailer set up so the wheels were well back and the drawbar always had decent weight on it, but there were some interesting moments. Especially under brakes.
