Clydesdales/Athenas (200+ lb / 91+ kg) Looking to lose that spare tire? Ideal weight 200+? Frustrated being a large cyclist in a sport geared for the ultra-light? Learn about the bikes and parts that can take the abuse of a heavier cyclist, how to keep your body going while losing the weight, and get support from others who've been successful.
What is flexing?
Old 09-28-06 | 09:45 PM
shakeNbake's Avatar
Mooninite
Bikes: $53 Walmart Special
What is flexing?
Wassup guys!
My chain rubs my FD whenever I stand up and mash on steep hills. I adjusted my FD properly, it never rubs otherwise.
I'm 240 lbs and I ride a Schwinn Fastback(the one in my signature). It's an entry level bike, so it comes with low level components to say the least.
So my question is, what's most likely to flex? The frame or crank?
shakeNbake is offline
Reply
Old 09-28-06 | 10:29 PM
There is always flex in the bottom bracket. It's made more noticable when you are are a big guy pushing big gears. How bad is the rubbing? Does it derail the chain or just click?
Have a look at this (look under "clicks"):
https://www.jimlangley.net/wrench/keepitquiet.html
Dewey Oxberger is offline
Reply
Old 09-29-06 | 08:55 AM
Hambone's Avatar
Bikes: GT Edge for the road/Specialized Hopper (well the frame and the bb, everything else is new) for the dirt
and where is it rubbing? (which part of the fd)
Hambone is offline
Reply
Old 09-29-06 | 09:31 AM
shakeNbake's Avatar
Mooninite
Thanks guys.
It's the chain rubbing the cage of the FD. It's just a noise, it didn't derail or anything. And it never does that except when I mash up a hill.
The rubbing itself doesn't bother me, I'm just worried that all those flexing could cause metal fatigue.
Reply
Old 09-29-06 | 10:01 AM
Hambone's Avatar
Originally Posted by shakeNbake
Thanks guys.
In my experience, long before you flex the frame so many times mashing up hills that it becomes structurally unsound, you will be riding a different bike. (Truth is, you will be riding your fourth or fifth bike before that bike is fatigued like that. And at that point, the bike will be under some delivery guy bringing you pizza.)
Hambone is offline
Reply
Old 09-29-06 | 12:27 PM
JOHN J's Avatar
Bikes: giant ATX 760, Falcon Road Bike (ss) custom marinoni tourismo (full dresser) ,
Welcome to the Clyde club.
yep that happens to many of us Bigger folks Esp with steel bikes.
I have a surly cross check and My bike often enough will auto shift when I start mashing due to bottom bracket flex I keep the cable well greased.
As for your FD that happens to lots of people Clyde or not , many times the FD just needs a better tuned adjustment.
Or get FD that has a greater swing range Thats what I did I went from a Deore LX (older) and installed a Plain Jane DEORE instead.
The plain jane Deore had more swing than My Deore LX so now I can move it away further when Im on my top ring.
"John"
JOHN J is offline
Reply
Old 09-29-06 | 02:31 PM
(51)'s Avatar
Perma-Clyde
Bikes: Trek Hybrid 7200
Happens to me too. I usually have to gear up or the chain starts slipping as well.
(51) is offline
Reply
Old 09-29-06 | 02:38 PM
Hambone's Avatar
slipping chain is something different. Is it slipping around the chainrings, the gears in the front? If so, you should check for chain stretch first. (Google it but basically you count 12 links of your chain and measure pin to pin. It should be within +/- 1/8 of an inch.)
Hambone is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
