the trashed cone thread
Quoted: 128 Post(s)
Liked 12 Times
I recently overhauled a Cannondale that a friend of mine had been given by his brother. Weird mix of parts (some incompatible), very much in need of overhaul. I needed to replace one of the bearing cones from the front wheel, and the old one was just crazily pitted. Pitting covered about 5/8 of the race. The intracacies of the pitting are pretty impressive. Also, the axle was difficult to turn when holding the locknut between thumb and forefinger (the wheel itself was heavy enough to turn for awhile under its own momentum, when mounted on the bike).
"c" is not a unit that measures tire width
Cool patterns. Classic example of what happens when the hub is adjusted too loose. All the force is on a few balls and the cones get worn. Lucky the races weren't damaged.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Quoted: 128 Post(s)
Liked 12 Times
That's similar to what was (starting) to happen with mine. What hub exactly was this? I got a pit after only 750 miles on a WH-R550 front.
I suspect that it might have to do with Shimano hubs coming with not-enough preload assuming that whoever has them will be using them with vertical dropouts or a front with lawyer lips and thus not put enough force on the QR?
Quoted: 128 Post(s)
Liked 12 Times
Quoted: 2026 Post(s)
Liked 1,096 Times
If you want to rebuild this hub you might have to find a "will fit" cone and play with spacers to make the wheel come out centered correctly. Check Bike Tools Etc. and Loose Screws to see if thay have the correct one.
We have a real "old fashion" LBS in the area that has boxes of odd-size and recovered cones from all sorts of screwy hubs. I've had to go through his stuff looking for a near match a few times. It can be a real adventure and usually I've had to settle for close-enough-is-good-enough.
Quoted: 128 Post(s)
Liked 12 Times
Since this is a recent-enough Shimano hub, I was able to find a replacement cone easily. It didn't look the same (machined race as opposed to hardened black race) and it was longer, but apparently it's the same length from the bearing-contact point to the wrench-flat end of the cone, so it took the same amount of spacers for properly-dished hut.
But older ones can be a real bear...
