Too much proofide?
Too much proofide?
I took my new brooks team pro s out for its first ride yesterday (35 mi), and yeah, it felt pretty damn hard on my sitbones (but not insufferable). Today I applied proofide for the first time (top and bottom), but I think I applied way too much. It was softer and gooier than I expected too.
What should I do? Do I need to let it sit for longer than overnight now? You can't ruin a saddle from just one application of too much proofide, right?
totally louche
Bikes: the ever shifting stable loaded with comfortable road bikes and city and winter bikes
Liked 10 Times
cook it in with a hairdryer.
nows about the time of year i start crayoning beeswax into my Brooks saddles along with proofhide or snoseal or obenauf's.
use a hair dryer and cook it in, no biggie. it will actually make the brooks more water repellant, the more glop you can force it to absorb.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
I am in the process of working over my brides new Brooks Lady's Saddle I heated the leather with a blow drier then covered the bottom with a heavy layer of proofhide, and covered the top with proofhide. Allowed it to soak in, wiped the top off and installed it on her bike. It will probably get an extra coating of proofhide on the bottom in a month or two. Then the ocassional coating and wipe off on the top as it breaks in. She is a very low mileage rider.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Bikes: LHT, Kona Smoke
Works great, just make sure you get the underside coated really well.
I'm made of earth!
Bikes: KTM Macina 5 e-bike, Babboe Curve-E cargobike, Raleigh Aspen touring/off-road hybrid.
Quoted: 10 Post(s)
Just rub it in as much as you can, and then let it sit overnight. It'll be fine.
How much are you supposed to be able to wipe off in the morning? There didn't seem to be much residue.
And what kind of bike is that fancy lady's saddle going on? It's very impressive.
Gemutlichkeit
Proofide is mostly beeswax. It's the oils that they add that can over-condition the leather, but you won't hurt a Pro with one heavy application. Those things are thick. The others are right, heat the saddle (I use the oven on low) and let things absorb. Later, when it cools, you can buff off any residue on the top with a cloth. Go easy on the Proofide. You can use alot of SnoSeal, tho. It has no oils so it won't soften the hide. Heat the saddle and apply liberally to the bottom only. Your motion and body heat will draw the beeswax thru within a couple weeks.
Gemutlichkeit
One other thing:
Brooks Pro saddles are not designed to ever be soft and pliable. They are a true performance road-type and are meant to be very firm. They are probably comfortable as perches and have all the absorptive wicking characteristics of hide leather, but any rider that buys one should understand that they will never be like a thinner gage hide.
I'm made of earth!
Quoted: 10 Post(s)
Quoted: 70 Post(s)
Liked 15 Times
Aaron
