building a fixie with vertical dropouts
audio champion
Bikes: 2006 Lemond Poprad
i want to build myself a fixie/ss but am new to this. i found a decent frame, but it has vertical dropouts on the back. how much of a problem will this be as far as chain tension, etc?
thanks!
thanks!
in grind we crust
Bikes: de rosa prestige 1982 track, de rosa prestige 1982 road, olmo team 1985 road, hoffy track, faggin track, 1981 bianchi piaggio track, d'accordi road, bob jackson singlespeed
sheldonbrown.com
eno hub
etc etc
eno hub
etc etc
o.O
it will work if you are ok with other than the exact gear combination you plan for. you will need to try some different combinations to find one that has good tension. if that's not acceptable, you can buy the ENO hub, but it's horribly expensive.
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
A "Golden Ratio" is terribly hard to find. And if you don't have several chainrings and cogs at your disposal. Even harder.
Dude, just try to find track/fixie frame.
audio champion
word. the thing about this frame is that it's cheap. track frames are 5x more expensive, at least, on ebay. i'll keep looking around though... just want a project to work on. thanks for the help, everyone.
o.O
Originally Posted by carleton
...and which part of that is good news?
D=RxT
one word, not two
i'm converting a newer mountain bike with vertical dropouts to a singlespeed, and i bought a chain tensioner. it's not as nice as not having one, but for the work it would take to find the right ratio i figured i would just use it. i got it for $1 on ebay(that was weird). that fixmeup website looks nice though...i might just do that now.
Elitist
Liked 92 Times
Not really. Have you tried it much? The easiest way to find one is to put on a wheel with a gear cluster (that's so hard to come across) and try combos until you find a good one. A half-link, about a dollar from the local hardware store, will make this significantly easier. Once you find a good combination acquire the fixed cog in that size.
1) my ratio was like 52/16
and
2) I vowed to never try it again.
Oh yeah, when you are working on a Golden Ratio, once you find it...that's it. You are pretty much stuck in that gear combo whether you are comfy with it or not...like my 52/16.
Carleton, though I am too tired to really explain it more in depth I can assure you that a magic, or golden ratio, and your 52x16 could have been altered easily. I forget exactly how off the top of my head, but it is possible.
Something along the lines of:
40x18 = 42x16...
40x18 = 42x16...
Elitist
Liked 92 Times
40x18 = 42x16...
40x18 = 42x16...
But, for each chainstay length, you get 2 maybe 3 magic ratios which are about 8 gear inches apart. And if I ever wanted to adjust to one of the other gear inches, I'd have to have/buy a cog *AND* a chainring. A problem easily solved by a rear-facing and (to a good extent) a horizontal dropout where you can change the rear cog from like 14-19t to your taste.
I'm not saying someone shouldn't do it. Just know what you are getting into.
Geek Extraordinaire
Bikes: Bianchi Advantage Fixed Conversion; Specialized Stumpjumper FS Hardtail
If you want to go single speed, you can just get a chain tensioner. If you want to go fixed, thats when it gets harder.
I'd rather have a bottle in front of me than a frontal lobotomy.
Sintesi Conversion Serotta Track
LF for the accentdeprived
Not desperately hard to build a vertical-drop fixed, just keep in mind two things 1)it is a hack 2)it is a hack.
Not too hard at all to find a magic ratio. Have a half link and a couple of rings and cogs handy and try them out, or try one of the online calculators. They may even work, who knows?
Be prepared that the chain will stretch... then you need to find a game plan. Mine was to pick up a file and attack both the dropout and the axle. Did I tell you it is a hack?
Sheldon Brown's posse
Bikes: BMC SL01, XtC, Rhythm GX and a frankenstein avalanche 2.0
I just built myself a singlespeed/fixie MTB out of a GT avalanche. Golden Ratio, 42/18 or with flattened axles 42/17 as well.
jack of one or two trades
Bikes: Old-ass gearie hardtail MTB, fix-converted Centurion LeMans commuter, SS hardtail monster MTB
antisocialite
the online magic gear calculator works perfectly. measure carefully (center of bb to center of axle) and you'll get it right on the first try.
however, your chain will stretch over time and you will either need to deal with the slack or replace your chain often.
it's even more advisable than normal to have a brake on there if you're running a magic gear.
Bike fiend.
Bikes: Giant STP SS, Trek 400 (Fixed), 1970's Orion, Huffy Flatbed BMX, Vintage Huffy Kids Cruzer, Vintage Sears Cruiser, Trek Prototype Frame (fixed)
You know, if it's not that great of a frame to begin with, you only need something like 1/2" of movement in the dropouts. A rat-tail file or jeweler's saw both work wonders, and half-links are cheap.
I've done it before, and never had any problems. Just don't take away any more material than you absolutely need to.
[edit] Sheldon also proposes filing down two sides of your axle, but I'd rather keep the axle whole, and file the dropouts.
You don't need 1/2". With an optional half link, only 1/4" is enough to make any ratio work. And if you're willing to drop or add 1 tooth in the front as the situation requires, then even less. (1 tooth will be <2 gear inch change... I doubt that you'll notice)
Again, it's preferable to find a setup where you're at the front of the dropout w/ new chain.
