q on axles for Shimano M525 Deore LX disc hub
é wot?
Bikes: Gary Fisher Montare, 1973 Bottechia, IRO Jamie Roy,1998 Cervelo Eyre Tri, 1982 Peugeot Sport fixed gear, and some kind of red bike hanging in the rafters
These are 9mm axles but biketoolsetc lists 9x1 and "9x1i" threads in a 9mm size - which is correct or are they interchangeable?
I'm looking to use this hub as a rear hub with bolt-on cog. Would this axle work? Are there longer axles available elsewhere? The length would be just sufficient with these (126mm rear spacing) but a bit more would be nicer.
é wot?
I should clarify that this is the front hub I'm wondering about.
Shirley someone knows?
