Touring bike w/nice ride.
Bikes: Trek 4300 X 2. Trek 1000, Trek 6000
I am considering looking for a touring bike, with relaxed geometry and longer seat stays to allow for use of panniers. Trouble is I am not really planning to do any loaded touring. Maybe just enough for a day tour etc. Most of the reviews i read suggest that most touring bikes ride poorly unless heavily loaded.
Is there one that rides well when barely loaded?
Bikes: are better than yours.
jon bon stovie
Bikes: bridgestone 400 fixed gear conversion, dawes touring bike (model unknown)
why not just use any road bike or mountain bike?
if you are only going to go on day tours, you probably won't need four large panniers. you can probably get away with only two smaller ones.
my trek 1400 road bike is by no means a tourer. its a late 80's/early 90's racing bike. but i would still trust in on tour that lasted for even a few days, provided i didn't weigh it down to much with panniers filled to the brim. you could also try a comfort bike.
Infamous Member
Bikes: Surly Big Dummy, Fuji World, 80ish Bianchi
Worse than a standard "race bike."
"Let us hope our weapons are never needed --but do not forget what the common people knew when they demanded the Bill of Rights: An armed citizenry is the first defense, the best defense, and the final defense against tyranny. If guns are outlawed, only the government will have guns. Only the police, the secret police, the military, the hired servants of our rulers. Only the government -- and a few outlaws. I intend to be among the outlaws" - Edward Abbey
Originally Posted by chipcom
A touring bike has a longer wheelbase, and therefore not as 'twitchy' as a racing bike and not as light. My Fuji World rides just fine unloaded, but isn't made anymore. Try a Bianchi Volpe, with some better tires and saddle. Jamis Aurora might also be a good choice.
Touring bikes are generally heavier, more stable, flexier and have a "softer" ride. Racing bikes are stiffer, handle more quickly and are lighter.
Different bikes for different purposes.
Bikes: 1984 Raleigh Kodiak Touring, 1992 Scott MTB, 2004 Fuji Touring
Just a suggestion...how about an older late 70's to mid 80's touring bike? I have an early 80's Raleigh Kodiak touring bike and it rides like a plush Cadillac. You get the old school lugged frame look, super-long chainstays, full-size frame geometry for a stretched out/relaxed ride (horizontal top tube, handlebar at or above seat level). Those older frames give a lively (although some would say flexy) ride. Not so important if you don't load up. You may need to upgrade a few things, so you have to like tinkering with your bike.
For comparison, I also have a newer Fuji Touring. Very stable and I love it for longer tours, but it's not as fun as the Raleigh for day rides. I have no problem riding it unloaded, however.
If $$$ is no object, how about something like a Rivendell Rambouillet?
https://www.peterwhitecycles.com/rambouillet.asp
(but, personally, I would get a retro 80's bike, and fix it up for 1/4 the cost.)
Mad bike riding scientist
Here's my reply to the same question over on the Clydesdale forum.
I'd start there and look up and down the entire line. The ones I've listed tend to be the less expensive, heavier models. But there are lots of higher level models that would be much lighter.
Originally Posted by cyccommute
But I think what you are looking for is something a bit sportier and not necessarily a full on touring bike. Lemond Etape, Specialized Roubiax, Specialized Sequouia, Trek Pilot, Giant OCR 1 or OCR2, Fuji Newest 1.0, Felt Z80, Jamis Ventura or Aurora (this is a 'touring bike' but it's a little short for my tastes as a loaded tourer), Bianchi Brava (get only the Celeste one
) would all be good choices. They are not true touring bikes but are relaxed geometry bikes. They are built more for century rides than for a criterium. There are others too. The ones I listed above, for which you'll have to do your own web searching
, were all selected because they have higher spoke count wheels and are a little heavier than a race bike. Most, if not all, are below $1000.
Stuart Black
Dreamin' of Bemidji Down the Mississippi (in part)
Stuart Black
If you want a confortable bike for day touring, consider a day touring bike. Typically these use long drop caliper brakes to take any tyre up to 32mm and have drop bars set at a higher position than race bikes and come with the relevant braze-ons.
The style is also known as sport road bike, audax, randonee.
It is a bit of a niche product so look at smaller brands.
The IF Club Racer is a nice example. See also Gunnar, Soma, Surly, Marinoni
Bikes: 2008 Turner Spot, Berg Ti Cross, 2011 Karate Monkey
pick your style
So to the original poster I say - pick the style of bike (ie Sport road), but don't get your heart set on one specific model. Get a highly experienced shop to do a proper fit, then scour the publshed geometry charts for the one which fits best. These sport bikes have longer steerer tubes to accomodate higher bar heights (w/o needing 10 headset spacers), slightly longer chainstays (but not as long as fullon tourers) for comfort and stability, the better tire clearance mentioned above, are made of double or triple butted cromoly steel, and usually have rack braze-ons at dropout and seat stays.
'Mizer Cats are INSANE
Bikes: C-dale T800
How much does a Volpe weigh?
Steve W
Infamous Member
Edit: Ok I was wrong, just went to my LBS next door and weighed a 58cm Volpe - 25.11lbs
I'd say about 22-23 lbs (stock). My Fuji weighs in at 25lbs with the rack and fenders
Prefers Cicero
Bikes: 1984 Trek 520; 2007 Bike Friday NWT; misc others
I bought a used 1984 Trek 520 on eBay. About 26-28 lbs with racks and fenders, at least it seems to be, based on the bathroom scale subtract your own weight method.
