Spray on Rainproofing?
Very Senior Member
I discovered this morning that my jacket is not as rainproof as it used to be.
What is a good brand of rainproofing that I can spray on the jacket?
It's better to cycle through life than to drive by it.
https://www.campmor.com/webapp/wcs/st...0226&langId=-1
I use this on the outer shell of my home made pogies.
Dam it is cold here!
Originally Posted by MichaelW
Nikwax wash-in proofing is probably better than a spray.
I have a Columbia OmniTech waterproof jacket and the same thing started happening, no longer beaded water and more just soaked in
Columbia told me simply to wash the jacket and throw it in the dryer with a towel and that would reactivate it. Worked like a charm. They also mentioned Nikwax if that failed
Thinking about picking up some Nikwax as REI and trying to waterproof my backpack. Think that would work?
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
Quoted: 5 Post(s)
Liked 7 Times
Nikwax wash in is the best that I've ever used. Spray-on's are not as good, and also can't be used indoors/unventilated when spraying/drying due to the chemical composition of the stuff.
First, before you go and buy $20 of Nikwax stuff (about $10 each for the pre-wash and waterproofing) try ironing your gear. I'm serious. It's a trick that I've picked up from being a distance backpacker for years and years. Low-heat ironing can reactivate the waterproofing on most 'breathable' fabrics, as long as you've never made the mistake of having them dry-cleaned or otherwise processed to break down the waterproofing.
"I feel like my world was classier before I found cyclocross."
- Mandi M.
- Mandi M.
Quoted: 5 Post(s)
Liked 7 Times
I've got a GoLite pack (not even close to waterproof) that I use as my commuter bag. I use a dry bag liner, and I've had no issues with keeping things dry. (And I carry a lot of important lab documents and electronics on my commute)
- Mandi M.
- Mandi M.
Also, washing you garment in a technical wash product like Nikwaxes tech wash or another product like Sport wash (found at walmart in the sporting/hunting department and some outdoor stores) or even Woolite Zero (almost the same product) and then drying in the dryer can really improve the DWR on some garments. I recommend washing your garment with one of these product prior to re-applying any DWR. Don't use a conventional laundry detergent and this can have chemicals in it that stay on the garment after the wash and can reduce the breakability, wicking or waterproofness of the garment.
p.s waterproofing a backpack or a bag is never a usefully thing, it can add SOME waterproofing but a packcover or a dry bag inside the bag is the only surefire method of keeping a pack waterproof (too many seams, zippers and the fabric is usually not good for waterproofing). There are some bags that are waterproof but if yours isn't already then I would just get the pack cover/dry bag instead.
It's true, man.
Bikes: Cannondale T1000, Inbred SS 29er, Supercaliber 29er, Crescent Mark XX, Burley Rumba Tandem
Do such wash-in products as NikWax have any good effect on regular fabrics, or is that wasted effort?
Quoted: 5 Post(s)
Liked 7 Times
I washed my g/f's nylon windbreaker with my GTX hiking raingear when I was waterproofing stuff last fall, and she's had no problems with it waterlogging, which it used to do quickly. I suppose it would depend a bit on the weave of the fabric, too. I doubt you could Nikwax wash a cotton t-shirt and stay dry with it.
- Mandi M.
- Mandi M.
It's true, man.
Originally Posted by CliftonGK1
I saw some hiking forums that mentioned Nikwax for making other (non-DWR) garments a bit water repellent, but it won't make them as good as something designed and made with an actual DWR fabric.
Very Senior Member
Well, sounds like the vote goes to Nikwax. I have to drive to work on Friday, I'll stop by the outdoor store and pick some up. Thanks, gang!
Quoted: 5 Post(s)
Liked 7 Times
Originally Posted by Varroa
They have a Nikwax for cotton and fleece. You could try one of those. The cotton one can make a t-shirt into a water bag for a short period of time.
I'm gonna use it on some bandanas and see if I can't use them as water scoopers in some of the creeks I filter from when camping.
- Mandi M.
- Mandi M.
I missed out on hearing about this stuff?!? Man... Now I have to go to REI, again.
Very Senior Member
