Cateye Opticube Problem
Old 11-30-06 | 08:55 PM
20 Anniversary
Bikes: '70s Puch sport tourer, '90 Peugeot Success.
I can't get this unit to secure to the bars. Is there some trick to it?
Mod. HL.EL.120
Cyclepath is offline
Reply
Old 11-30-06 | 10:10 PM
20 Anniversary
Bikes: 2 many
You pull the rubber strap until it is tight and then flip the little plastic clamp down. The clamp locks the strap in place and tightens it a little.
2manybikes is offline
Reply
Old 11-30-06 | 10:24 PM
20 Anniversary
Tried that - doesn't work. The clamp doesn't have enough tension in it to hold the strap. I prefer the older type that latch on positively.
Reply
Old 12-01-06 | 10:15 AM
20 Anniversary
Bikes: 2 many
I think know what you mean. In an attempt to make mine more secure, I pulled the strap really tight and pushed down the clamp so hard I broke half of the plastic clamp off.
Did you push the clamp all the way down until it stops against the strap? It's definelty hard to make it stay in place. I got mine to work but it moved around on a ride. I had two of them. I finally gave the good one (without the broken clamp) away and went to something else.
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
