A passing...of a bike
Bikes: 2004 Martin Novato w/ 2004 Burley Nomad
It's very sad to say this, a loved one passed away today. She was about two years old. With 10613 miles on her. The frame broke, took out two sides of the frame. I have no clue how it happen. Here are some photos. I think my bike has a lifetime warrantee on the frame. I have to call my LBS in the morning when they open. Only thing that's original on the bike is the frame. I guess being car-free is hard on a bike.
SERENITY NOW!!!
Bikes: Haro Vector, IRO Rob Roy, Bianchi Veloce
Sorry for your loss. She served you well.
HHCMF - Take pride in your ability to amaze lesser mortals! - MikeR
We demand rigidly defined areas of doubt and uncertainty!
VOTE FOR KEN WIND
I think that many manufacturers will replace frames even when there is no sign of a defect. As long as there isn't neglect or abuse involved it's a good policy.
Recumbent Evangelist
Bikes: Rebel Cycles Trike, Trek 7500FX
She will be remembered as a selfless organ donor, I'm sure.
spinspinspinspin
Originally Posted by vendorz
Is there something about the break that makes you think it is related to a manufacturing defect and not simply about ordinary wear and tear?
Good luck with the new frame- hope it gets to you soon.
I just had pick up a new rack, after installing it I was the crack. I though it was a paint problem, I was so wrong. It did start at the bottom bracket weld, into the next tube and all away around. Almost connected to the other side. I think they just don't make bikes like they use to.
Thanks for all your support!!!!!!!!!!!!!!
SERENITY NOW!!!
Let us know if you can get a replacement frame under warranty. Good luck!
I will, I am going to hear today or Thursday. It will be coved otherwise I will rase hell. The bike before this frame also broke, after the frame broke two times, they gave my this bike (Martin). I don't know why they keep braking. I saw just how bad it was after I striped the bike. I am so bad I saw it before riding her again. In three years I have broke 3 frames.
Bikes: Mercier Corvus (commuter), Fila Taos (MTB), Trek 660(Got frame for free and put my LeMans Centurian components on it)
She was too young to die. When will we learn? When will we fix the potholes that kill those we love before their time?
Where have all the downtubes gone? Long time passing, where have all the downtubes gone........
Sunrise saturday,
I was biking the backroads,
lost in the moment.
Sunrise saturday,
lost in the moment.
Good luck with the warranty...
Quoted: 25 Post(s)
Liked 21 Times
That stinks. The problem with a frame warranty is that you don't get a "loaner" bike in the meantime! I've heard stories of people waiting 6+ months to get their replacement frames. On top of that, the new frame often has different specs than the old one (which they have often stopped making by that time), so they have to buy new parts! Hardly a warranty.
I hope you have a backup bike to keep you riding. Goodl luck!
Wow, still no word. It's been sent out. He told me it might be four or five more days.
10,613! Thats more miles than I ever put on my car in two years!
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Quoted: 25 Post(s)
Liked 21 Times
Originally Posted by squeakywheel
Just a flesh wound.
Seriously, either you landed hard jumping that thing or it's a manufacturing defect.
Defect for sure. Apparently, if it's going to fail, it will happen in the amount of miles that the poster has put on the bike or much fewer. Once you get above that you should be golden (for steel certainly and for a long time with AL). Look at that dude who rode his old 3-speed around the world. 44 years and 335,000 miles on that bike...
About metal fatigue
When you repeatedly apply force to a piece of metal, in general, it will eventually fail. The higher the force, the fewer cycles to failure, and the lower the force, the more cycles until failure. However, when the force falls below a certain threshold, called the endurance limit, you can repeat the application of force forever, with no failure.
The actual measure for the endurance limit is in stress, not force. Stress is force per square inch. This means that if something is stressed above its endurance limit, you can always make it last longer just by making your metal thicker. You may even make it strong enough that you drive the stress below the endurance limit, and then it will never fail (under normal usage).
For aluminum though, the endurance limit is always asumed to be zero (if it is non-zero, it is too small to be useful). You can never get below the endurance limit, so eventually, every aluminum bike frame will fail. The reason consumers accept this is that (hopefully) aluminum frames are made with the metal thick enough that the fatigue failure doesn't occur until peak cycles get up into the hundreds of millions, or higher.
For steel, however, the endurance limit is comfortably distant from zero. Practical steel supports can be designed that should never fail during normal operation. The endurance limit for steel typically comes into play on the order of one million cycles; in other words if something has survived a million cycles of stress, it should never fail (due to that level of stress). For a bicycle at a rather slow cadence of 60 RPMs, this is less than 280 hours of riding.
There are certainly many riders capable of accumulating this many hours of out-of-the-saddle riding time in a single year, and a few who could get in a million cycles (out of saddle) in just a couple of months. And most of these riders have frames which have lasted them much longer than this. This is simply not the time scale in which frames should be failing. From this I conclude that steel-framed bikes are generally designed with all normal usage falling below the endurance limit.
One of the things this means is that if you do have a steel frame failure, it is due to one of three things: You exceeded normal usage (e.g. crashed), or the frame had a manufacturing defect, or the frame was poorly designed. Note that crashing may not cause immediate failure, but it can lead to a failure later on. For example, a crack in a frame will redistribute stress to the areas around the crack. These areas will see significantly more stress than they saw before there was a crack, and hence may be prone to an endurance limit failure.
Bikes: Bruce Gordon BLT, Cannondale parts bike, Ecodyne recumbent trike, Counterpoint Opus 2, miyata 1000
That was a very strange crack in your thumbnail picture. Extending straight across the weld, far past the weld, and with a sharp angled bend in it. Wierd. I suspect brittle metal failure. Like the excessive sulfer in the hull metal of the Titanic. Since it has hapened twice I suspect someone knowingly used tubing that was not meant to be welded. If you had received serious trauma I would have suggested taking it to a Forensic Metallurgist.
Well still no word on the bike, but the bike store did give me a bike to use.
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
Looks to me like a good excuse for getting a TIG conversion kit for the welder.
Work: the 8 hours that separates bike rides.
Quoted: 25 Post(s)
Liked 21 Times
Now that is surprisingly good news. The way these stories usually go is that the bike owner ends up buying a new bike b/c the company takes so darn long to send a new frame. The fact that your LBS gave you a loaner bike gives them big points in my book. You may have that loaner for a while it this keeps up though...
Well they have the same frame YAY!!! No need to buy new parts. It was shipped today...so it's going to be awhile to get here. The LBS is good to me, I have dropped over $10,000 on bike, gear, and so much more. So thats the main reason they give me a bike to use. Also they know I am car-free, and my bike is my life.
Quoted: 25 Post(s)
Liked 21 Times
I'm glad they've been good to you. And I'm hoping $10,000 is an exaggeration! Unless you've got the carbon-fiber/unobtanium version of the Novato.
I'm also not 100% sure if getting the exact frame is a good or bad thing. It's extremely good that you don't need to change any parts. But you did break 2 of those frames already, right? I hope this one lasts longer!
