Threaded headset, what stack height?
I need a 1 inch headset for a 87 Rockhopper, the head tube length is 127mm and the fork steerer is 92mm. So do I simply need a stack height of 35mm or is there more to it?
Thanks in advance,
Dave
Thanks in advance,
Dave
Quoted: 2026 Post(s)
Liked 1,096 Times
You need a headset with a stack height of 35 mm or less. If the stack height is less than you calculate, you can add spacers to make up the difference. If the stack height is more than 35 mm you need a steerer stretcher.
Quoted: 128 Post(s)
Liked 12 Times
Just for the record, I assume it's proper to measure the steerer tube from the base of the crown race seating point to the end?
"c" is not a unit that measures tire width
Liked 1,096 Times
