other than that butt numbing crash.....
Old 12-15-06, 01:05 PM
rider of the east
sherpaPeak's Avatar
how do you figure out if your frame has a crack or not....
okay.......after last weekdends of trail riding my bike needed some cleaning...I finally go the time on wednesday night to take care of it...while I was sashing down the down tube I found a 3 inch hairline mark on the frame/tube. First I thought thought that it may be the mark on the decal...further investigation shows that its not the case......I can feel the hairline separation on in the tube (may be the paint or may be the frame itself).....
now, how could I determine if its a crack or not? I know that I can take it to a local store etc.....I was wondering if there is an obvious way I can determine it before taking it to sewhere else...
thanks for your help
sherpaPeak is offline
Old 12-15-06, 01:15 PM
a magnifying glass and a good light works well
mcoine is offline
Old 12-15-06, 01:19 PM
Moar cowbell
dminor's Avatar
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times in 5 Posts
You may be able to 'ping' up and down the downtube (like with a knitting needle, chopstick or whatever you have on hand) and listen. There will be changes in tone from the butting in the tube, but once you get around the area of the suspected crack - - if it is a crack - - there will be a dead 'tick' instead of a 'ping.'
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
dminor is offline
Old 12-15-06, 01:45 PM
rider of the east
sherpaPeak's Avatar
I did that......that was my first test.......but as I am not experienced, at least not with cracks......I can hear that there is a thicker ping at the middle of the tube where the suspected crack is...but I can not really be sure. now, if you strike on a tube with a metal the sound created by the either end would be different than the sound created by the middle.......so, the slightly thicker sound that I am hearing..is it the crack or is it just the physics of an hollow tube....
dminor, thanks for your help........that is a wicked bear you have up there.....
Old 12-15-06, 03:08 PM
Moar cowbell
dminor's Avatar
Quoted: 29 Post(s)
Only way to know for sure, of course, would be dye penetrant testing (which, if you could find a lab, might cost more than the frame) - -it's like magnafluxing for non-ferrous metals.
Short of that, you may have to scrape away enough paint and clean down to bare metal for a better visual inspection.
The bear - - Friend of mine (actually my old mentor) - - an old-school illustrator and cartoonist - - did that caricature of me and the bear.
dminor is offline
Old 12-15-06, 07:50 PM
unofficial roadie
DirtPedalerB's Avatar
Bikes: 2004 Marin bobcat trail, 2006 trek fuel ex7, 2007 iron horse road bike
if it's right in the middle of the tube I'd keep riding it and watch and see if it expands.. usually the cracks are near the ends at the welds or maybe where the butting begins or ends.. more then likely it's a scratch..
post a pic for all the experts here to overanalize.
DirtPedalerB is offline
Old 12-15-06, 08:23 PM
wheelhot's Avatar
Bikes: 2017 Specialized Roubaix, 2007 Giant Anthem, Polygon Quatro
Quoted: 103 Post(s)
another way is to see if you cant stuck something thin (maybe like paper or thinner) into the crack and see if the paper went inside
wheelhot is offline
Old 12-15-06, 09:46 PM
B*ck From Th* D**d
WannaGetGood's Avatar
Bikes: 2015 Kona Process 153
Quoted: 23 Post(s)
Liked 8 Times in 6 Posts
Feel it.
WannaGetGood is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
