TA Track Pedals with clips and straps
señor member
Bikes: Malvern Path Racer, Schwinn LeTour, Follis, Bridgestone 400 (RIP), concord 2sp
Okay, so I have a set of those TA track pedals, that I was putting. I installed the clips and went to put on the straps, but the cage is waaaay too small to fit straps through. They have nothing on the MKS ones. It's less than half the width of the strap. Is there any other way to make these work. I could just go under the cages, but that doesn't seem to make sense. Any ideas?
crotchety young dude
Bikes: IRO Angus; Casati Gold Line; Redline 925; '72 Schwinn Olympic Paramount
(Water-based = water.)
Water based lube=
(Uploader)
Bikes: KHS Pursuit, Pink Soma Cross
Originally Posted by mattface
Water based lube=
Hmm, I've only ever used water, but if lube (no, not THAT lube) works, might as well.
señor member
Water based lube=
Originally Posted by luvthemas
That's the kind of **** I used, it works like a charm.
Triathlon = Eat/Bike/Nap
great for cramming things into tight holes.
Overstating the obvious.
