Spoke problem.
Bikes: many
Spoke problem.
I am in the middle of re lacing my wheel. I'm running into a problem every time. What happens is i lace the wheel to 3x. Everything seems to be done correctly. If i have a spoke on the left flange of the hub it goes to the corresponding hole. But for some reason some nipples are flush with the wheel, and some just stick out. Why is this happening?
1978 Schwinn Varsity Single Speed
Making a kilometer blurry
How far are you in lacing? (e.g. which step out of four?)
Do you have another 3x wheel around you can use for reference? Set them against each other and look closely.
Bikes: many
I already redid everything 3 times, still the same thing. I'm about to get my spare 3x wheel.
feros ferio
Quoted: 1384 Post(s)
Liked 1,293 Times
Are your left-flange and right-flange lacing patterns synchronized? If all of the too-long and too-short spokes emerge from the same flange, this is your problem. You are underwinding half of the spokes on one flange and overwinding the other half.
Quoted: 1572 Post(s)
Liked 642 Times
Do you have a pattern of two tight spokes followed by two loose spokes? If that's the case, then your pattern is off by one hole relative to the two hub flanges.
Bikes: many
If it helps im lacing a rear wheel. So what you guys said is what is exactly happening. Can you guys explain on how to lace it up correctly? the way i do it, i followed Sheldon Browns instructions by placing the valve stem hole at 12 o'clock and putting the key spokes in so that they there is a spoke on every other hole on the hub and a spoke every other 3 holes on the rim. This sound correct?
Bikes: many
Originally Posted by taken67
is it dished, or do you have a flip flop hub?
Gone, but not forgotten
Bikes: See: https://sheldonbrown.org/bicycles
Quoted: 24 Post(s)
Liked 6 Times
Sheldon "https://sheldonbrown.com/wheelbuilding" Brown
Bikes: many
Originally Posted by Sheldon Brown
Nope, a spoke every 4 holes. (When you have laced the first of the four groups there will be 3 empty holes between each pair of spokes.)
Bikes: many
edit: I just went and gathered all the old spokes, and placed them all together and some are a bit shorter then others but some looked stretched because of over tightening.
Liked 642 Times
Those are pretty long spokes. Is this for a 27" rim?
Bikes: many
Originally Posted by Retro Grouch
I doubt that's the case. It's common for the drive side spokes to be 1 or 2mm shorter than the spokes for the non-drive side. That's close enough, however, that you can usually make it work even if all of the spokes are the same length.
For any number of spokes cross there are 4 groups of spokes (e.g. 4groups of 9 for 36 spokes) 2 on each side. Sheldon advises this order: right trailing, left trailing, right crossing, left crossing. I find it easier to do a whole side at a time (right trailing, right crossing, left trailing, right crossing). It is easier to spot your mistakes.
see:
https://www.bikewebsite.com/build.htm
see:
Quoted: 24 Post(s)
Liked 6 Times
see:
see:
High-production wheelbuilders commongly insert all of the spokes into the hub before they even pick up the rim, but I've never done it that way.
Sheldon "Whatever Works For You" Brown
Code:
+-------------------------------------------------+ | What is good for you is what is good for you. | | --Peter Chisholm | +-------------------------------------------------+
