Volpe tires and first MS150(in PA)
Bikes: Bianchi Eros and Volpe, Pinarello Galileo
I have my first MS150 coming up in June. I did a 140 mile 2 day trip on flat trail last year on my Volpe with the tires it came with and it was perfect.
The tires I believe are called Tiranasaurus or something like that. Kind of knobby. I was wondering if I should consider different tires for the MS150, use these tires or consider using the Bianchi Eros I have instead?
Any and all opinions welcome and appreciated.
Thank you.
Jim
Thank you.
Jim
Quoted: 19 Post(s)
Liked 7 Times
Terrainosauras are a fairly heavy mixed use style, suitable for trail and road. If you switch to a medium width (28-32mm) slick, with a pressure of 90-100psi, your ride will be much more efficient and faster. For light touring, a kevlar banded model like Panaracer Pasela are good.
Thank you.
I assume this means new rims and new tubes. Any recommendations here?
Since I have not changed a bike tire in 30 years I think the LBS will get the work.
Censorship Stinks!
Bikes: Three
I would strongly suggest that you go ahead and change the tires yourself. If you are not comfortable with it, it will give you a good chance to get familiar with removing the wheel and tire to change a flat. <---Which you will NEED to do sometime on the road. (Do you carry a spare tube / patch kit / tire levers / pump or CO2?)
Matt
Matt
Good point. I do carry everything and it would be best to have a first go at home.
A Heart Needs a Home
Originally posted by pedal-n-paddle
Thank you.
Thank you.
If you want to replace the tubes, you can carry one of the current ones as a spare.
Just do it yourself. This is a skill you need to have.
RichC
Training: 2002 Fuji Roubaix Pro (105 triple)
Commuting/Daytripping: 2001 Airborne Carpe Diem (Ultegra/XTR, touring wheels)
Commuting/Touring: 2000 Novara Randonee (Sora/Tiagra/LX, fenders, lights)
